This doesn’t look good...
Gaskets are metal and reusable. Just don't bend them [obviously] and wipe them clean, along with the mating surfaces, before reassembly. You'll likely have to use a rubber mallet to break the rocker plate free from the push rod tube. Go easy; the tube is just held in place with an o-ring at each end. Also, *BE VERY CAREFUL* not to let the dowel pin, under the intake side of the rocker plate, come loose and fall down into the oil drain back hole. The hole is in the perfect spot for the dowel to fall in and end up in the bottom of the crank case.
does the head have to come off to do the lifter replacement?, and if so, what gasket are needed or not needed?
That's right...better to run it a little fat than a little lean.
I added this to my “break in" and "post break in" oil change ...
about 1 ounce per quart of oil.1 Photo
I get chills in my up and down my spine when I hear people say, "i've been using the same oil for years with no problems"…........
Previous owner must have cheaped out on the oil or didn't observe appropriate service intervals. I lived in Killeen for 20 years. Can't say I miss it.
I did not. Should I? I think I should....
start it running and crack open the oil line on left side of bike, right? Oil everywhere = good pressure and just a drip means an issue...if I remember reading correctly. Idling at 850 to 900 RPM...
BTW....what is redline for these 1600s? How do you know aside from hooking up an aftermarket tach?
Glad you got it back on the road.
Did you by chance check the oil pressure after you put it back together?
Amazing... These bikes can go 200k-300k with normal maintenance and no issues... And a bike with only 10k miles wipes cam and lifters (probably due to wrong oil)... Sucks.
Rich don't hurt , maybe a mile or two on miles per gallon .
I was worried starting it all up the first time!!!
The info posted on this site is extremely helpful.
I also just added a Barons jet kit and K&N filter. I ran the 170 main and am planning to drop to the 167.5. I think that’s right...or whatever the smaller jet is in the kit. I’ll start there.
Anyways rode it today and it did pretty well. Just think it’s a bit rich...
Got the cams replaced as well as the lifters. Found a lifter case used on EBay and replaced the gouged up one. Got it all back together and have put about 150 miles on it so far.2 Photos
Started by roadiemort, 13 hours ago
1 hour ago
Started by MikeyC, 12-05-2020, 08:08 PM
92 responses
8 hours ago
Started by MikeyC, 3 days ago
8 hours ago
Started by Jeffw, 1 day ago
10 hours ago
Started by BC1955, 5 days ago
by BC1955
14 hours ago
Started by Rilcoat, 4 days ago
14 hours ago
Started by Doc_V, 09-23-2020, 02:48 AM
80 responses
15 hours ago
Started by LDofDC, 12-23-2020, 12:17 PM
120 responses
22 hours ago
by Rilcoat
Started by zert800, 1 day ago
by zert800
Started by AZRoadie, 4 days ago
by EP Roadie
Started by TexFer, 12-30-2020, 10:46 AM
by TexFer
Started by Rilcoat, 2 days ago
by Rilcoat
NRA
by roadiemort
Started by roadiemort, 3 days ago
Started by Duke, 3 days ago
by roadiemort
3 days ago
by roadiemort
3 days ago
3 days ago
