This doesn’t look good...
  • Copecountry93
    Originally posted by Bikerron View Post
    It’s what many of us on here use and it’s got the numbers I can appreciate.
    Ok just making sure. I made a post about handbags. Not alot of people have chimed in. Any advice you could give. 14 and up bags
  • Copecountry93
    Two words; Flat tappets. PO probably was using cheap ass oil with low ZDDP content.
    Just an observation and some food for thought.
    There are many blogs out there about flat tappet cams and their appetite for zinc and phosphorus.
    https://www.bobistheoilguy.com/forum...e-2016.296170/
    I use mobil 1 twin 20w 50 is that good or should I use something different? I dont want this happening to me.
    There are many blogs out there about flat tappet cams and their appetite for zinc and phosphorus and all of Yamaha’s big pushrod V twins use them.
  • tovarman2
    I bought the bike used. Don’t have much info from PO as he was no longer "available" to ask questions.
  • tovarman2
    I was interested in others opinions. Own a few motorcycles over the years. Never had anything like this happen with any of my other bikes.
  • tovarman2
    I have not. Just discovered issue this morning and am not running bike. I was intending to replace the cams and lifters. Drain oil change filter. Run bike for a bit. Change oil and filter again. Pray.
  • grubsie
    Originally posted by Lug Nut View Post
    Odd thing to have happen on a Road Star
    Actually it is common. Old oil or wrong oil for a Roadie will cause this quite easily. I know it has been beaten to death on here, buy using oil without sufficient zddp (zinc) in it wreaks havoc on flat tappets and the flat tappet cams. It's just as simple as that.
    Originally posted by tovarman2 View Post
    Thoughts on the lifter case? Anyone think I could clean that up and reuse? Or does it appear to need to be replaced?
    I saw an article or two on valve lifters from the local auto parts store. Good to run those versus OEM?
    When I look around the net for OEM cams I am seeing around $400 to $500 a set. Yikes! Is there no way to replace just the rear cylinder cam or do they have to be maintained as a set ( not to mix a new one with a "used" one)? Thoughts?
    I am open to all suggestions!
    Have you drained the oil yet and cut open the oil filter to see if there are metal shavings in it? I'd be willing to bet there is metal in the oil and the filter. If so, there are metal shavings throughout the engine and in the oil tank. Not a good situation.
  • tovarman2
    Ah. Found the rest of the pics.
    That lobe is toast.
    picture upload site
    Cam looksnok from that Pic.. Lifter bad. Probably replace both cams and lifters as a set... Odd thing to have happen on a Road Star
  • tovarman2
    99 Roadstar with a lil over 10k mikes. Transmission recall had not been performed so took it to a local shop to have completed. While in there had them upgrade the oil pump gear per what I read around here. Recent oil change too. Mobil 1 V-twin synthetic.
  • tovarman2
    started a topic This doesn’t look good...
    Was riding along when bike lost power. Rear cylinder dead. Got home after work and temped rear exhaust coming out of rear cylinder and reading was very low. Opened her up to see what was up and noticed the intake rocker arm on rear cylinder was not rotating enough to open/close intake valves. Got to lifter and lifter case and found this...
Started by boomerA, 3 days ago
Started by rdpickard, 1 week ago
Started by Miles phrampus, 1 day ago
Last Post SbTx_Rider
Started by scotcher65, 1 day ago
Last Post Ahodge75
Started by Sparkeee277, 1 day ago
Started by drumsonly2002, 2 days ago
Last Post BubbaKahuna
Started by AR. Hillbilly, 4 weeks ago
Last Post D.Overton
Started by Shores, 1 day ago
Started by Mike383, 3 days ago
Started by Dr Jay, 5 days ago
Started by Doc_V, 3 days ago
Last Post KCpartsguy
Started by Kevin, 3 days ago
Last Post Aussie John
Started by El_Mipo, 11-02-2018, 11:15 AM
75 responses
Last Post scotcher65
Started by FDRUCaptain, 4 days ago
Started by Lug Nut, 4 days ago
Started by Kevin, 2 days ago
Started by MikeyC, 6 days ago
Started by Sharpman66, 2 days ago
Last Post Chooch
by Chooch
Started by HotRod, 01-16-2021, 11:20 AM
Last Post HotRod
by HotRod
Started by Gravydog, 6 days ago
