Barnett clutch upgrade
  • Barnett clutch upgrade
    The clutch in my 2001 roadstar is starting to slip under load so its time to replace. I'm getting ready to order the barnett spring conversion kit, for anyone on the clinic that has done the conversion what were the noticeable differences? Also did you have to buy new clutch disks and the metal discs?... I would imagine the kit doesn't come with new discs
    I need to do it on mine as well. The previous discussions here and the old site have indicated that the barnett kit is enough. The clutch plates are typically just fine.
    Peace,
    Baron Wilhelm Gustav von Schmidt III
    (But you can call me Joe)
      Clutch plates are USUALLY OK, you have two choices on Barnett spring strength, make sure you index everything with the plate and basket knotches before you put the cover on or you’ll have to redo it, some folks have had issues with a bearing going out after the Barnett install, left hand will become as strong as your right!
        lol... well ebay had a deal I couldn't refuse 270$ for the entire combo clutch Barnett spring conversion kit, Barnett carbon friction plates and steel plates!
          That's what I used. Still works great after 27k miles.
          Soak friction plates in ATF for about 3 hours before installing.
        • daveto
          daveto commented
          is atf really suitable to soak in? If yes then I wasted a litre of ams oil for nothin!
          No waste on your oil, ATF will not hurt your oil. Friction plates will suck up the ATF and is one of the best oils for them.
        Patiently waiting for it to arrive in the mail... Does anyone have torque specs for clutch case cover and for the clutch ?
          The cover is about 88 inch pounds. The stock spring retainer is 68 inch pounds. I just did mine with an EBC spring and just got home from a ride. Feels great! Also changed the engine and transfer case oil.
            I just installed the Barnett pressure plate with springs. Clutch works great now and engagement point is just about half lever travel which is where I like it.
              I got the barnett conversion shown above and i changed the sprins to the red ones. Stiffest ones i could find. 99pounds of force per spring IF i remember correctly.
              Installation is a breeze, just watch the installation video you can find on youtube. It has one step that you might get confused with. It had something to do with how you need to place the part so it goes straight right.
              But great conversion! Very pleasant even with stiff springs
                I have to replace mine soon I started to notice more slippage last summer and I will tackle the task this year.
                If everyone is thinking alike, then somebody isn't thinking
                  There's another alt here if you can find some old stock at a yami dealer which is Yami did also mfg 2 high perf clutch springs to replace the weak stock type clutch spring,1 is approx 20% stiffer and the other is approx 25% stiffer under High Perf Star Accessories.
                  My friend put 1 in his 05 R* which is at approx 70-75k miles now with no clutch slippage using the original clutch plates and spacers the bike came with new.
                  Below i will post the info from Yami on those clutch springs.
                  Scott
                  STAGE 3 CLUTCH SPRING WITH 20% MORE HOLDING/CLAMPING STRENGTH FOR STOCK MOTOR WITH PIPES,BAK,PORTED INTAKE,DYNA3000,ETC. Yamaha Competition Clutch Spring The spring rate is 20% stiffer than the stock spring for increased clutch capacity. Reduces clutch slippage and resultant heat build-up under heavy use. Designed to handle increased power output from Stage IV configuration.Manufactured By: Yamaha Fits '08-'11 Road Star and '02-'09 Warrior
                  Item: SPD-5PX09-84-00 Usually Ships In: 5-6 Business Days MSRP: $152.95/Our Price: $122.36
                  STAGE 4 CLUTCH SPRING BETTER SUITED FOR HIGHER PERF SETUPS WITH HI COMPRESSION PISTONS,HI PERF CAMS,PIPES,BAK,PORTED INTAKE,HI PERF HEADS,PIPES,ETC. Manufactured By: Yamaha Stage IV for 98 & 102 cu. in. The spring rate is about 25% stiffer than the stock spring to handle the increased power output from Stage IV configuration. Fits '99-'07Road Star models
                  Item: SPD-4WM09-84-10 Usually Ships In: 5-6 Business Days MSRP: $113.95/Our Price: $91.16
                  BTW,these clutch springs fit later R*'s too thru when they stopped making them,it's just that it was quite a few yrs ago when i gathered this info which is why the listing stopped at some yrs back.
                    I went CHEAP and put an EBC thicker than stock in mine with new Friction Discs. $56 at Dennis Kirks, new spring seat too. Got 97,000 miles out of my OEM and this EBC is wat thicker , SO !
                      FYI, there's NOTHING better than Yamaha plates & Barnett SR-2. NOTHING!
                        I like the simplicity of the stock configuration, fewer parts.
                        • gillis.jordan
                          gillis.jordan commented
                          The Barnett pressure plate conversion literally makes the setup more simple than stock.
                        Took a nice 377 mile breakin cruz Friday. All hills and variable tight to loose turns thru these Ozark hills I live in. This RaceTech front end combined with my good 'ole Flipped lowered Roadwing is the TITS. Had to force myself to slow down some 'till I really get the hang of it. Hope the new Star has this Good of suspension ! And I did everything I could to break this EBC clutch loose but , this baby GRABS ! Real glad for the new C2 on the rear. Also shifts with NO CLUNK , imagine that. Only problem I'm having is my hands and shoulders were weak after 3 months out of the saddle , WOW !
                          Father Pobasturd commented
                          I'm real happy with my EBC spring too.
                        The OEM spring plate is garbage, the clutch plates will slip winding out the bike.
                        the spring conversion is designed to eleminate this slippage.I have installed
                        brand new plates in my bike and the plates still slip winding out the bike, (yes the steel plates are all positioned correctly) i am hoping this spring and plate conversion will elemenate this irritating slippage.
                        i also like the clutch to engage at the bottom of ithe lever not mid point of the lever bring let out. I like all of the friction zone not when the clutch is almost completely engaged.
                        I would like to know if this conversion will fix these issues.
                        • J89k
                          J89k commented
                          Should totally fix your slipping issue.
                          Your other issues are a cable adjustment issue. I found I had to do minor adjustments at the lever when the bike got hot.
                      Started by Pauli466, 1 day ago
                      Started by MrG, 1 day ago
                      75 responses
                      Started by WarPig, 13 hours ago
                      Started by Oldsguy1, 2 days ago
                      Last Post Oldsguy1
                      Started by Blackcloud12, 07-27-2020, 10:42 PM
                      47 responses
                      Started by Lug Nut, 10 hours ago
                      Started by Doc_V, 2 days ago
                      Started by Roadtalker, 16 hours ago
                      Started by Horsehammerr, 2 days ago
                      Last Post Paladin
                      by Paladin
                      Started by Pauli466, 18 hours ago
                      Started by Tsilk87, 18 hours ago
                      Last Post MrG
                      by MrG
                      Started by Shores, 02-21-2018, 08:16 PM
                      Last Post universes
                      Started by McVinny614, 2 days ago
                      Started by Shores, 3 days ago
                      Started by Shores, 1 day ago
                      Started by Lug Nut, 07-22-2020, 05:21 PM
                      143 responses
                      Started by scotcher65, 2 days ago
