Engine guys need your input: Working w/ maker of Rocker Lockers to make a R* version
Most of noise isn't the shaft moving in the saddles it's from the rocker arm wearing into the inner shaft, replacing just the inner rocker shaft will quiet the top end down considerably, i even thought of moveing the rear rocker shafts to the front and vice versa so tops of the shafts where the rocker arms had wore into them would now be on the bottom and the bottom where there's no wear will be at the top making a tighter fit to the arm, i couldn't believe how much the rocker arm wore into the inner shafts on mine. Had to be over 10 thousandth's of an inch easy, seeing as the inner shaft isn't all that expensive new i might just change them out, i think ill at least do the front cylinder as that's where most of the noise is
Dave yes that insert is sticking out just a tad it was a first prototype and was a little large for the hole and did not pull in all the way. The next set that I sent to Doc was a little smaller and pressed in much better, did not mushroom. His hole was 23/64 those would have worked better with 3/8.
Hey guys just joined, yea I am Steve from Rocker Lockers, Yes I ride a Harley, no I don’t want to hear it, get over it, sarcasm is another word for rude, LOL.
I have not read all the post so forgive me if I repeat something that has already been stated.
Yes HD has the same problem but on our bikes the hole for the bolt aligns with the notch in the rocker arm shaft. So the hole does not need to be drilled out.
There are several fixes that have been perused, Loctite the shaft where the shaft fits inside the tower, this has worked pretty well but is not a permanent fix.
An old fix was to drill and tap for a set screw in the tower to lock the shaft. This worked well but weakens the tower and had several break at the screw especially with high lift cams with stronger springs. Some put the set screw on top some on the side.
Maybe a set screw from below would work.
Yes a shoulder bolt would cure the problem ( larger shoulder smaller thread size) but finding a shoulder bolt the right size could be hard to do at least for the HD, it is 5/16 thread with 11/32 shaft, custom made is very expensive, (8 bucks a peace min order required)
You could fabricate some sort of a lock to go into the tunnel of the shaft, a clamp of some type, but that can get to complicated.
That is why the inserts have been the most practical yes there are several who have copied my design but Mine are the original.
The standard Rocker Lockers will not work, the Twin Cam are to small and the Evo the taper is not long enough so I have made up some custom to fit Doc’s bike.
To fit the notch in the shaft the bolt hole needs to be drilled out to 3/8, however we were concerned about removing so much material from the tower. I feel that the bolt will reinforce the hole enough but that is not my call. For doc’s bike he is going to drill the tower hole out to 23/64 and there will still be a small amount of play but very little rotation of the shaft.
Personally if it was my bike I would go to 3/8 but if it broke I would only have myself to blame.
Doc does not have a drill press, so he is going to use a hand held drill that is another reason why we decided to go 23/64, it is easy to go off of center with hand held. A dill press would be much better assuring a perpendicular hole if you went the 3/8.
These are custom size and I am only making them up as they are requested, I am asking 20+5 for shipping. It takes me an hour or so to make them plus cost of material.
Yes the rotation and tick does not hurt anything other than being annoying and yes it can be very annoying.
Yes even if your shaft is tight in the tower don’t let this fool you, it can still rotate and tick when it get hot. Due to the coefficient of expansion of the different metals aluminum expands far more than that of steel so when plate is cold the shaft will be a press fit when the rocker arm plate gets hot the steal shaft will fall out of the aluminum tower.
We have found that most bikes when new do not have a ticking problem but when they get some miles the shaft loosens up starts ticking about 50k (not all). Also with any high lift cam the extra pressure on the shaft can cause it to start rotating, or any top end work seems to start the tick.
Anyway that about covers it if I think of anything or any questions please ask.
Dave or Doc, can you look at oil passages to see where the oil is flowing thru the rocker plate? I was wondering if the 1700's oil line is for cooling the heads, and the push rods are the oiling for the rockers like the 1600's.
Dave, the 1700 RLs arrived. My digital calipers are cheap, so those measurements are give or take.- OD is 9.02 x 9.65
- ID is 8.15 x 8.81
- Length 31.85 mm
I understand what you are saying now about the 1700's I didn't know they were different until now. In this case the rocker locker might be the easiest fix if they can be made to fit. When I had mine apart for the head work I didn't pay any attention to whether the bolt had a thru hole or not.
I like Duke's bolt idea, it's pretty slick for the 1600s, but at the end of the day, it'd require a separate larger bolt for the 1700, and you'd still have to drill out the tower to take up the play in the shaft groove; the end result would be pretty much the same as the Rocker Locker. Seems like 6 of 1, half dozen of another.
Where did you get the one in the prototype pic? I have a set of the Rocker Lockers for the HD's.
Hey Doc, can you tell if the cut-outs on the new shaft and old shaft pictured are the same size? I'm also wondering if the retainer bolt is a different size?
By looking at your pictures the retainer bolt looks to be a different size. The bolt that Smokescreens is making up, might not work for the 1700s.
Not sure. In his last email he mentioned he sent me out a set for the R* to test. I'll measure them when they arrive. I have a feeling, even if the diameter is the same, the length is likely different. Apparently the first one he tested for the R* mushroomed, so he had to trim them.Last edited by Doc_V; 10-01-2020, 10:59 PM.
Started by rondo_calrissian, 4 hours ago
3 hours ago
by DEEPHATE
4 hours ago
Started by Lug Nut, 6 days ago
by Pauli466
6 hours ago
Started by AreikUSA, 06-30-2020, 10:50 PM
by Dave A
7 hours ago
Started by Dave A, 3 days ago
by Chrominator
8 hours ago
13 hours ago
Started by jd750ace, 1 day ago
17 hours ago
Started by AR. Hillbilly, 02-01-2020, 11:31 AM
164 responses
by jd750ace
17 hours ago
Started by jd750ace, 3 days ago
by jd750ace
17 hours ago
Started by Jaybo, 1 day ago
by roadiemort
17 hours ago
Started by LDofDC, 3 weeks ago
68 responses
20 hours ago
Started by MiLawyer, 10-03-2020, 02:44 PM
21 hours ago
by EP Roadie
Started by SbTx_Rider, 1 day ago
by SbTx_Rider
Started by Blackbeard, 2 days ago
by jd750ace
Started by HotRod, 1 day ago
by jd750ace
Started by Jaybo, 2 days ago
Started by Sharpman66, 1 week ago
by Sharpman66
Started by Jinro, 12-08-2020, 06:02 AM
Started by Smoke, 08-02-2018, 10:02 AM
by Pauli466
