Mccruise Electronic Cruise Control
  • Mccruise Electronic Cruise Control
    Does anyone have a procedure on installing Mccruise's electronic cruise control on a 2005 R* Midnight Silverado? It's going to be about a $1,000.00. I wanted to get some input before I spend the money.
    1/3 the value of the bike?
    Never heard of anyone installing one.
      Sorry for my ignorance, I don’t see Yamaha roadstar listed on their site and am assuming this system is designed to work with electronic throttle bodies or drive by wire technology?
        Your just kidding..... Right? Spend $180 and get the Break A Way throttle lock and ride.
          I've contemplated adding electronic cruise to my R* but haven't gotten there yet. There are some options out there that are far less than $1000.
          Here's a Rostra kit at Murph's Kits (I've never dealt with them just happen to have seen this site before). Murph used to offer a clone of the Audiovox CCS100 that was a bit cheaper than the Rostra but used a vacuum actuator instead of the electronic servo.
            My CHEAPASS THROTTLE LOCK works just fine.
            • Brad_G
              Brad_G commented
              Nothing wrong with simple or cheap.
            The Rostra kit is around $300.00 dollar at Summit. It is a universal kit, and there a few youtube videos of people installing it on bikes.
            There is no listing for the Road Star on their website, but there is for the V-Star 1100 and it uses the push - pull cables similar to the Road Star.
            You can do a search and find it on other websites.
            https://www.summitracing.com/parts/rpc-250-1223
            You will also need to get the switch control pad.
            Rostra 250-3592 Dash Mount Cruise Control Switch
            https://www.amazon.com/gp/product/B0...JLYNL7Q4&psc=1
            and maybe the 250-4165 Magnetic VSS Speed Pulse Generator Kit for Rostra and Audiovox Cruise Control
            https://www.amazon.com/gp/product/B0...A3ELPGJLYNL7Q4
            I have not installed one of these but I checked on this setup a few years back. I'm sure you would have to fab up the brackets for it to work on your Road Star.
            Good luck and ride safe.
              I've got me one of these. [Thanks for the recommendation RodieRob.] It's made of aluminum, took less than 10 seconds to install, and for less than $12 you can't go wrong. Mine does the job nicely; you just have to be attentive when using it and not become forgetful.
              Rests on the brake lever to hold throttle open. Roll off throttle manually to disengage GoCruise. Made from 6061 machined aluminum.
              • Brad_G
                Brad_G commented
                I have something just like it. Helps reduce fatigue but still isn’t like having true cruise.
            144 responses
            Started by mariner3302, 16 minutes ago
            Started by psychoal, 11-05-2019, 07:28 AM
            Last Post psychoal
            Started by Shores, 02-21-2018, 08:16 PM
            42 responses
            Last Post chromax
            by chromax
            76 responses
            Started by Pauli466, 2 days ago
            Started by MrG, 1 day ago
            Started by WarPig, 23 hours ago
            Started by Oldsguy1, 3 days ago
            Last Post Oldsguy1
            Started by Blackcloud12, 07-27-2020, 10:42 PM
            47 responses
            Started by Lug Nut, 21 hours ago
            Started by Doc_V, 2 days ago
            Started by Roadtalker, 1 day ago
            Started by Horsehammerr, 3 days ago
            Last Post Paladin
            by Paladin
            Started by Pauli466, 1 day ago
            Started by Tsilk87, 1 day ago
            Last Post MrG
            by MrG
            Started by McVinny614, 2 days ago
            Started by Shores, 4 days ago
