Help Oil Leak!!
  • D-Fresh
    Awesome!
  • Horsehammerr
    So Far , back to normal
    Originally posted by Bikerron View Post
    Wouldn’t hurt to check all the hoses in the general area. The oil tank has a vent hose that’s prone to crack and leak, as well.
    I’ll be dogged.
  • D-Fresh
    Hopefully you got it this time
  • Horsehammerr
    Finally spotted a very tiny hole on the inner side of rear head vent line . Right at the Tip of the nozzle going into the oil tank . Boy , talk about HIDDEN ! Well I thought it was fixed before , so we shall see once more .
  • Horsehammerr
    I suppose the best way to use this is in the dark with the motor running , Choke Gag Cough ?
    This isn’t some new fangled stuff. Been around for ever. Any reputable parts house can hook you up with a fluorescent oil leak detection kit.
  • Horsehammerr
    Where can I get this Dye ?
    The best way to find a "hard to find leak" is with leak dye and a black light.
    Any source for a leak can be traced back to its origin.
    You just haven’t found it yet.
    possibly too much oil in the motor, possibly fuel is overflowing carb while off going into bike past rings, adding to engine oil?
  • Horsehammerr
    OK replaced Oil Feed and Return Line "O" Rings and all was well . Until I slowed in town at Bike , Blues and Bar b que yesterday when stopped the slight OIL LEAK showed again dribbling down the Transfercase face. I've been searching this Leak for 3 weeks now . Any answers to where this is coming from ? All rubber Hoses check out and can not find gasket leakage anywhere . HELP !!!
    looks like dried up gas from puke to me too , alot tho, could be fire hazard. go over the carb.
  • Horsehammerr
    Well I got it apart , waiting on OEM o rings. That " Plug " in the top hole at the bottom end of the sending oil tube is a piece of CRAP rubber plug , nothing else. It covers a perfectly threaded hole , the cheap basterds could not simply put a bolt in. It will have one for it's remaining life.
    that is they way it is supposed to be. Kinda odd but correct.
  • Horsehammerr
    Started to pull oil tubes and noticed upper bolt on bottom end of return tube has no bolt . Looks like a blank stud. What the heck ??
  • Horsehammerr
    Got all 4 coming . Will renew them all for another 107,000 !!!
    I had to replace those orings on the eagles bike to correct an oil leak on the lower side.
  • Horsehammerr
    I wonder how an O ring behind a flat flange against a flat mount surface could "wear out ? " and leak ? That's what happened to my upper oil feed line on my '01 Midnight . I mean HECK ! it hadn't leaked for 107,000 miles . How is this possible ?
Started by RoadieRob, 11 hours ago
Last Post RoadieRob
Started by Knutselsmurf, 18 hours ago
Started by Pauli466, 12 hours ago
Last Post Questcap
Started by ctkog, 8 hours ago
Last Post Questcap
Started by Ret HPD, 11-23-2019, 02:49 PM
Started by Father Pobasturd, 01-12-2020, 11:43 PM
1,341 responses
Started by Sguitard, 4 days ago
Last Post Smokescreens
Started by Aussie John, 1 week ago
Started by Pauli466, 2 days ago
Started by 2time, 1 day ago
Last Post 2time
by 2time
56 responses
Started by Lifeguard, 2 days ago
Last Post Lifeguard
Started by ian pemberton, 1 week ago
Started by coreys1982, 2 days ago
Started by LUV4RS, 4 days ago
Started by Cubo55, 5 days ago
Last Post Lucky
by Lucky
Started by MikeyC, 4 days ago
Started by Pauli466, 2 weeks ago
Started by tapeit59, 2 weeks ago
