Pulley shaft O-ring?
  • MikeyC
  • MikeyC
    Oh, good, Jaybo is a little cone shaped too so there should be no problem.
  • JoeBloShmo
    The inside of the collar is cone shaped only goes one way. Possibly backwards?
  • D-Fresh
    Thanks. I was wonder how many miles i might have before that may go out on mine.
  • Jaybo
    58k roughly?
  • D-Fresh
    How many miles on the bike Jay?
  • Tykes_Place
    I remember that o-ring being a bit finicky. It's doesn't seal the way you think an o-ring should. It acts more like a gasket.
  • J89k
    Shouldn't be too bad. There are a few posts here about it.
  • Jaybo
    Aha, I may have missed that. Thanks Dave
    look at the collar #24 and see if the inside of the inner dia ends are the same. 1 end may have a small recess for the oring to set in to keep from crushing it as you mentioned.
  • Jaybo
    Hmmm, but it started leaking not long after I installed the new one, so was not sure I did it right. I'll try it again as shown and see what happens this time.
    Yes it get crushed if that is what you want to consider it. It seals oil from leaking between the shaft and part 24, then part 24 seals the outer with the seal part 22. I hope that makes sense. It has to seal in 2 places using the #22 seal against the outer diameter of #24, and then seals the shaft with the oring
  • Jaybo
    DaveJ I saw that, and pretty sure I installed it that way when I replaced it a little over a year ago. Doesn't it get crushed if you put it on that way? I could not find any O-ring left at all when I pulled it apart since it was leaking again.
  • KCpartsguy
    I think my bearing there is going bad, not looking forward to that fix.
    number 23
  • Jaybo
    started a topic Pulley shaft O-ring?
    Could someone explain or show a picture of where exactly the pulley shaft O-ring is supposed to be placed on the shaft? TIA
1,011 responses
Last Post Ironman
by Ironman
Started by joe29, 23 hours ago
Last Post joe29
by joe29
Started by area1509, 16 hours ago
Last Post RRS_07RdStar
Started by Road Star Charlie, 21 hours ago
Last Post scotcher65
Started by Mr300game, 17 hours ago
Started by McVinny614, 1 week ago
89 responses
Last Post rsokie
by rsokie
Started by roadiemort, 08-22-2020, 03:09 AM
172 responses
Started by Mr300game, 1 week ago
Started by Cmw2212, 04-26-2018, 07:38 PM
Started by Lifeguard, 2 days ago
Started by Blackbeard, 2 days ago
Started by Blackbeard, 1 day ago
Last Post Blackbeard
Started by estrom, 6 days ago
Last Post Baxter85
Started by JohnnyBGreen, 3 weeks ago
Started by LUV4RS, 2 days ago
Started by Sluggerknuckles, 2 days ago
Started by jinxpress, 2 days ago
Started by GreenMachine, 08-13-2020, 12:19 PM
250 responses
