Clutch replacement (uh-oh)
  • Jclevesque
    No you do not
  • 6feet
    Just my two cents on torque wrenches...I have at work a Snap-on torque wrench checker. What I can tell you is that most people over torque bolts because of the way they use the torque wrench. My advice is use 10 to 15% less torque than asked for unless you have a digital one. The digital torque wrenches are really accurate and reduce user error by a wide margin proven on the Snap-on device. YMMV.
  • cap-tech
    TimB So, everything is finished. Got my new Barnett cable +12 thanks. I had a motion pro prior and have arthritis in my hands. After being on bike all day my hand would be numb, with this new cable it feels like a new bike with a hydraulic clutch, I’d say at minimum a 4 pound difference in required squeeze pressure. Absolutely amazing, if you are reading this and don’t have a clutch cable from Barnett, order it now I paid to have it rushed and received in two days. For this reason I am ordering the clutch plate conversion,
  • Lucky
    That stock spring is lousy. Get the Barnett clutch spring and pressure plate. Amazing difference. Also those bolts should be tightened down in a cross pattern a little at a time.
    Do not tighten down one bolt to its max .
  • Lucky
    If a bolt has oil on it, the torque will be 10% higher than what you want.
    Deduct 10%. Only use a inch pound wrench.
  • J89k
    Do you still need this spring if doing barnett conversion?
  • cap-tech
    Here is a service manual pdf for the 1600. http://www.werder.ee/Manual/XV1600.pdf
    for anyone reading this post in the future the clutch spring does “bottom out” all the way up against the pressure plate. To the torque specs of 5.8 ft lbs are for once the spring is fully compressed.
    I don't have the PDF but if you look on Ebay you can find factory manuals for less than a Clymers. I just bout a brand new factory manual with the 1700 supplement for less than $25 shipped. It is a 500 page manual
  • cap-tech
    Anyone happen to have clymer pdf?
  • cap-tech
    No it did not come with this part. Came with the wire(that goes all the way around basket) gasket all friction plates including the one behind the wire and all clutch plates.
  • Jclevesque
    Did you new spring kit come with a new gasket ring called the housing spring #26 in the parts fiche? The Yamaha service manual does not show this to be replaced but the Clymer does. I do believe people that have only changed out the spring and not this housing have seen slipping not too long after the install. The housing spring sits in the pressure plate and diaphragm spring is on housing spring. Take a look at Partzilla it clearly shows how it goes together.
  • cap-tech
    Will stop in dealer tomorrow to order. Thank you that didn’t cross my mind.
    I dont know that I would get grade 12.9 bolts for something that calls for 5-7 foot-pounds of torque. Need a weak link in that system actually. If you over torqued and had megasuperbadass bolts your basket would be the weak link. Get stock replacement bolts and torque with 1/4 in torque wrench (70 in/lbs).
  • cap-tech
    Well I knew about the Barnett but I found the entire kit for 100 dollars. I figured I’ll go ahead and replace and when the time comes that my pockets aren’t empty I’ll get the Barnett. i don’t think the housing is damaged. I am going to buy a 1/4 inch torque tomorrow and found grade 12.9 bolts that is the same exact length so going to attempt to extract the bolt tomorrow. When torqued down to spec does the clutch spring sit flat against the pressure plate?
  • Jclevesque
    Too bad you didnt ask before cause most of us changed out the clutch spring to the Barnett plate conversion only that come with new bolts. The friction discs are usually still within spec. I had 94000kms and still good discs. You should watch out for torque settings that low. I used a 1/4” drive torque wrench in inch pounds settings. I have read torque wrench settings can differ 20% at the low and high range settings. Hopefully you did not damage the aluminum basket and only the bolt.
  • cap-tech
    started a topic Clutch replacement (uh-oh)
    So my R* has been slipping in higher gears for a while. My clutch kit came in today and it’s my daily driver so decided to start since I’m off for the weekend already.
    Got the clutch back together put the pressure plate and clutch spring back on and bolted down. Seen the service Manual calls for 5.8 ft lbs if torque and doesn’t specify to replace the bolts. Set my torque and the bolt broke off in the clutch housing.
    Question is are these bolts actually supposed to be replaced, when it says 5.8 foot pounds does that mean the clutch spring is collapsed all the way against the clutch housing? Finally can I replace the bolt with a typical grade 8 bolt or do I need to get the actual bolts?
Started by boomerA, 1 minute ago
1 view
Started by Do Something, 9 hours ago
Started by Primetime64, 4 hours ago
Started by 2000 Roadstar, 2 hours ago
Started by Neverdone, 10 hours ago
Started by Swampy, 21 hours ago
Started by DEEPHATE, 8 hours ago
Started by DEEPHATE, 1 day ago
Last Post 07 silverado
Started by DEEPHATE, 10 hours ago
Started by Infantryjared1, 5 days ago
Started by Blackcloud12, 02-25-2020, 05:10 PM
Started by Road Star Charlie, 05-22-2019, 04:21 PM
Started by roadiemort, 2 weeks ago
Started by RTT, 1 day ago
Last Post RTT
by RTT
Started by Mic39, 2 days ago
Started by scartozi, 3 days ago
Started by Road Star Charlie, 09-02-2019, 07:59 PM
Last Post Road Star Charlie
Started by Road Star Charlie, 01-14-2020, 03:53 PM
Started by Ledan, 1 week ago
Last Post Cheezhead
97 responses
