Fluids and plugs
  • LUV4RS
    Right on. Appreciate it Shores
    75w90 synthetic in transfer case
  • LUV4RS
    Lugnut mentioned using 75w90 in the transfer case then the thread moved primarily to engine oil. What is everyone else using in their transfer case? Thanks all.
  • 07 silverado
    Technically it's 20w40, but that is not readily available
  • 07 silverado
    I use Lucas full synthetic 20w50 in iowa, and I ride my bike down in the 30's for temps., I also use a synthetic gear fluid gl5 that I get at walmart for the transfer, ngk plugs, dot 4 brake fluid.
  • Jaybo
    Mobile 1 20/50 VTwin oil here in Oregon.
  • SuperG
    20w50 works just about everywhere - there are a few days in New Mexico I wouldn't be against a 20w60 though, but it's expensive.
  • Jon D
    I use 20w50 in Pa
    I've been using 20W50 for fifteen years in Northern Iowa
  • MrG
    Is the heavier 20/50 recommended for our bikes? Here in central Kentucky we get some days of temps in the 90s but it's not like Texas or southern Florida. Seems like a lighter oil would make it to the top end faster.
    Just want to make sure she stays tip top
    DOT 4 is the recommended fluid for our bikes. You can use better fluid DOT 5.1, but DON'T use DOT 5.
    Full synthetic V Twin oil for wet clutch... Need high zinc content... AMSOIL V Twin, Mobil 1 V Twin, Rotella T6 all work perfect
    NAPA gold or premium oil filter (Rebranded WIX / WIX pro)
    PRESTONE SYNTHETIC DOT 4 BRAKE FLUID AND SOME EBC HH pads are a great combo
    Transfer case fluid... Mobil 1 synthetic 75w-90
    Stock NGK 5129 spark plugs gapped to. 34-.38
  • MrG
    started a topic Fluids and plugs
    Fluids and plugs
    What weight oil do you guys use in your 1600s? I plan to use synthetic, had been running 10/40 in my Vulcan 800 but not sure if I should go heavier with the larger displacement and different configuration. Not used to having to deal with transfer case oil. 80/90 synthetic? Some car rear ends will leak if you use synthetic oil in them and I don't want to hurt my machine.
    Can we switch to DOT 4 brake fluid without consequences? Supposed to handle heat better.
    And finally, is there any real benefit to iridium spark plugs? What heat range?
    The only mods to the bike ( so far) is intake and pipes.
Started by reddog3979, 08-27-2018, 08:04 AM
Started by Boatmark, 1 day ago
Started by roadiemort, 22 hours ago
Started by roadiemort, 08-22-2020, 04:09 AM
279 responses
Started by Father Pobasturd, 05-22-2019, 06:24 PM
Started by davej, 2 days ago
Started by Michael72, 09-02-2020, 11:48 AM
Started by Slammed&Cammed, 1 week ago
Started by Father Pobasturd, 6 days ago
Started by brianmac, 1 week ago
67 responses
Started by Doc_V, 3 days ago
Started by Bip_Bip, 6 days ago
Last Post Bip_Bip
by Bip_Bip
Started by Lifeguard, 02-16-2019, 09:07 PM
Started by brianmac, 11-06-2018, 08:57 AM
101 responses
Started by roadiemort, 6 days ago
Started by Darkkill57, 5 days ago
Started by Lifeguard, 1 week ago
