Pms screw
  • Coach
    This one
  • Coach
    Hey Shores, yes I changed the oil 3 weeks ago, no change in level. I have the alley cat from SSCC. I rerouted the crankcase breather to its own filter and it’s still clean
    Did you change your own oil last? Have you put any oil in since 4 quarts were added? Is your air intake filter oily?
  • Coach
    Excellent Doc, thanks
    Blue smoke at start up means oil. Its possible you've got oil pooling in the cylinder after you shut down. Could be valve guides, though I haven't heard of anyone having that problem on a R*, but there's always a first. It's not serious as long as you keep an eye on your oil level.
    As for PMS, turning right/clockwise is leaner, opposite is richer. 2.5 turns out is a standard "best guess" for most situations but ideally you want to "tune" it by dialing in (clockwise) when the bike is HOT, until the idle drops or stumbles, then stop and turn it back out (counterclockwise) about a quarter turn. I currently have mine set to 2.25 turns, which is ideal for my set up.
    Check your plugs before assuming.
  • Coach
    Hey Lug, I have a small amount of blue smoke at a cold start, and soot at the exhaust end. I was running very lean before i rejeted and I may be spot on now but if I knew which adjustment to make with the pms I may be able to fine tune it.
    Your spot on with jetting and pms adjustment now....m what makes you thinks it's rich?
  • Coach
    started a topic Pms screw
    Pms screw
    I’ve recently installed a alley cat air cleaner on my 03 1600. Ais removed. V&H 2 to 1. I’m running rich. My pms is 2.5 turns out with 167.5 main and 37.5 pilot jet. To lean out a bit would I turn the pms out or in?
    thanks
Started by SPislanderATX, 5 hours ago
Started by badger2078, 1 hour ago
Last Post badger2078
Started by TataMichas, 5 hours ago
Started by Bricejevinn, 7 hours ago
Last Post Bricejevinn
Started by petr.hw, 14 hours ago
Started by Pauli466, 6 hours ago
Started by Shores, 8 hours ago
Started by TEXenvy, 3 days ago
Started by Father Pobasturd, 3 days ago
Last Post Zman
by Zman
Started by Herrindude, 3 weeks ago
Started by JD64k, 03-27-2018, 06:39 PM
170 responses
Last Post JD64k
by JD64k
Started by Primetime64, 2 days ago
58 responses
Started by Father Pobasturd, 01-12-2020, 11:43 PM
1,476 responses
Last Post TheBru
by TheBru
Started by toms03se, 4 days ago
Started by coreys1982, 1 week ago
Last Post coreys1982
Started by Agpilot, 3 days ago
