BAK Questions & Jetting Confirmation
  • Spydr
    Been there, done that with Jets R Us *and* Sudco.
    I have needles that *were* the closest to our needle size that they *had* at the time. Close, but no banana. Too short and/or too rich.
  • Tug
    Originally posted by Jaybo View Post
    Well it looks like Mikuni makes it just a little harder than Keihin for getting the proper tapers and whatnot than Mikuni does. I got a call in to a mikuni expert and see if he has a way to track it down. I'm assuming they use the #7 series needle but I will need to measure my stock CV needle and figure it out. You can see the specs of richer and leaner needle profiles on the Jetsrus needle page. It looks like it could just be a matter of simple measuring of the aftermarket needle and compare with regular Mikuni needles.
    The kit sellers may very well be making their own custom needles, but in the off road world Keihin needles were simpler to figure out and we always laughed at people who would spend $50+ on a Dynojet kit when you could buy individual jets and needles for well under $20. That was where my original comment came from, since Keihin made it easier to figure out.
    I will look into it a bit more and see what I can find out, because as my wife says, I could very well be wrong
    There will probably be a lot of interest in a cheaper needle vs buying a whole kit from barons
  • Jaybo
    Originally posted by Tug View Post
    Where do you get the needle?
  • SKWEARpeg
    Mr. Shamrock reprofiled several stock needles. You still need to pick up a few shims, to adjust elevation as needed, because the stock needle only has a single groove.
  • Tug
    There was a member on the old forum that was re-profiling OEM needles to the barons profile. But I can't remember who it is and I don't have a barons needle to reference for comparison. I know he is a bike flipper and that he was/is doing them for his own projects.
    can't buy just a needle for the OEM carb. You have to buy the whole kit. I recommend Barons and only Mikuni jets.
  • Spydr
    Yeah, Jaybo. Where did you find a correct needle for sale without buying a kit?
  • Tug
    It's a lot cheaper to just buy the individual jets and needle. For your elevation I would be starting with a 170 / 37.5 / needle in the middle with washer and spacer.
  • flyinj
    Thank you all for the responses!
    FlynJ
  • Jaybo
    Aha, I missed that, That much of an elevation change though he is going to be on the leaner side, CV carb or not, IMHO.
  • SKWEARpeg
    Originally posted by FDRUCaptain View Post
    My 1700 runs great with a 172.5 main, 40 pilot, 4th groove, and 2.5 turns . I'm at 1'100 feet.
    This one ^^^^^
    ....for a 1700 with intake and exhaust mods.
    I will add, the stock CV carb compensates for elevation by design. Not necessary to alter your jetting from what is mentioned here, to accommodate an elevation difference.
  • FDRUCaptain
  • FDRUCaptain
    That sounds like 1600 jetting if I remember correctly.
  • Jaybo
  • Mark_N
    Yes, Baron's kit comes with the jetting mods and you'll definitely want to rejet. Check out their site. Here is the link you need --> https://www.baronscustom.com/catalog...264/index.html
  • flyinj
    started a topic BAK Questions & Jetting Confirmation
    So, three questions follow a description of what I have going on. Just wanting to verify everything before I place an order...
    I have a bone stock RS1700, as far as I know, other than the previous owner removing the baffles from the stock exhaust. It backfires on deceleration and hesitates a little bit when leaving stop lights and stop signs etc. I've noticed the last few days that this doesn't happen if I leave the choke pulled out about a quarter of the way. I plan on removing the AIS, and installing a higher flow intake (BAK or similar). This all points to needing to jet the bike I'm assuming. Eventually, I will also install a different exhaust but that will be later down the road as the budget permits.
    First question... Do the Barons Big Air Kits come with the jet kit? I've seen this referenced a couple times. If true, I would essentially be killing to birds with one stone by ordering one of their BAK's.
    Second question... I still need to buy a Mikuni 40 pilot jet separately correct?
    The jet settings I've seen referenced on the forums for 1700's are:
    172.5 Main Jet
    40 Pilot Jet
    clip in the 4th groove with 1 washer and plastic spacer, PMS at 2 - 2 1/2 turns out
    Third question... Does any of this need to change if I live and ride mostly between 3500 - 4000 feet?
    Thank You,
    FlynJ
Started by Blackcloud12, 38 minutes ago
Started by roadiemort, 12-29-2019, 01:18 PM
50 responses
Started by Felix805, 17 hours ago
Last Post Felix805
Started by Jimfed1, 21 hours ago
Started by WarPig, 3 hours ago
Started by Penguin, 09-12-2019, 02:56 PM
Last Post WarPig
by WarPig
Started by Herrindude, 2 days ago
Started by Jaybo, 18 hours ago
Started by Father Pobasturd, 05-24-2019, 03:51 PM
869 responses
Last Post JoeBloShmo
Started by Father Pobasturd, 01-13-2020, 12:43 AM
251 responses
155 responses
Started by Aussie John, 1 day ago
Last Post Aussie John
Started by Thee_masonator, 2 days ago
Last Post BubbaKahuna
Started by thunderace4, 09-08-2019, 03:43 PM
Last Post thunderace4
Started by thunderace4, 10-19-2019, 12:34 PM
Started by Doc_V, 3 days ago
Started by Jaybo, 2 days ago
Started by Pressure, 3 days ago
Last Post Herrindude
Started by Bricejevinn, 01-20-2020, 10:00 PM
