Carb issues
  • NCB
    Originally posted by Rastin View Post
    Is this the filter I need or was that just an example? I'll order it if that's the one.
    This is the one I use: Emgo Crankcase Vent Filter Kit 14-20900
    They sell replacement filters, so you don't have to but the entire setup every time!
    Emgo Replacement Filter 14-20905
    I mounted mine in the front wear to AIS was mounted, some mount them to the left side rear horn mount. Hope this helps!
  • SKWEARpeg
    Anything like that. You can get them with a hose barb, and also a small bracket attached so you can mount them somewhere, instead of just letting them terminate below the bike.
  • Rastin
    Originally posted by NCB View Post
    Looks like (Carb Puke) the vent from the top left of the carb has been routed to where the crank vent would be. Relocate that vent hose to somewhere under the bike. Find the crank vent and connect a crank vent filter to the end of it and mount where ever you like. Like this one.
    https://www.summitracing.com/parts/v...4aAh3jEALw_wcB
  • V-Max
    That doesn't look or sound very pleasant. I do think that some hoses got crossed. If you can get some pictures of the hose running to the back of that hole it would be helpful.
    Originally posted by SKWEARpeg View Post
    Thats the crankvent isn't it Dave.
    supposed to be the crankcase vent but looks like someone got things mixed up a bit. Even though things got mixed up gas shouldn't be coming out. If it isn't gas and is connected correctly I would check for a pinched crankcase vent hose. That would allow pressure to build up inside the motor and release the pressure over a short bit of time after the motor is shut off. Also if it is the crankcase vent I would remove it from the back of the airbox and do the vent mad. Having the vent to the back of the box makes a gooey oily mess inside the head on top of the intake valves.
  • NCB
  • SKWEARpeg
    If you choose to relocate the line, don’t forget to plug the hole in the back of the air box.
    The vent is designed so the carb sucks the hot oily vapor and blowby from the crankcase, and combust it.
    It tends to trash the air filter prematurely and adds hot oily air to the intake where cool and fresh is much nicer. That’s why it gets relocated.
  • Rastin
    Ok, thanks for the information. I'll take that to my friend and see what we can do. It may have done it before, but it never made that noise. Thanks again.
  • SKWEARpeg
    Are you sure. I’m only asking because you can’t see it normally. On the stock set up, the crankvent line vents to the inside of the filter itself. You can’t see it with the stock filter element in place.
    A lot of us have relocated the crankvent line down below the bike in most cases with a small filter on the end so it can breath.
    Both of my bikes have it rerouted up under the tank to a filter attached to the ignition housing.
    If........the bowl vent got connected there instead, it wouldn’t be oily. It would be gas and gas fumes.
  • Rastin
    Is there no way to stop it then? It didn't do it before.
  • SKWEARpeg
    On the 1600’s, the crankvent line connects at that location on the back of the air box. The bowl vent simply terminates at a metal fitting on the back of the box. It doesn’t enter the air box.
    That looks to me like simple water vapor and condensate, which is typical on a hot motor.
    Sorry about the year of bike question, you filled out your profile it just took me an extra click to get there.
  • Rastin
    I didn't smell it, but my friend said it smelled like gas with an oily texture.
  • SKWEARpeg
    Does what is coming out there smell like gas, or engine oil. That could be condensate cooking off, which is normal, and should be wet and oily not gas smelling.
  • Rastin
    It's an 03, I took my bike to him because I know nothing about carbs. So I have no idea what hose connects to that area.
  • SKWEARpeg
    What year of bike, and what hose is connected to the back side of your stock air box at that location? I’m pretty sure the hose that connects there, comes from the crankvent on the top of the rear rocker.
  • Rastin
    I asked him to tune me up, replaced intake, installed Baron Jets and new plugs. Runs better than ever except for that issue when I shut down.
    Looks like you need to add more water to your coffee maker.
  • SKWEARpeg
    Originally posted by davej View Post
    What kind of carb work did he do? Rejet? Change the float level? More details of the work he did and the reason for the work would greatly help. There will be a bunch that will tell you to remove your fuel pump to resolve the issue but I'd like to find the problem for the issue and correct it.
  • daveto
    Someone else will give you a proper answer soon. But I can’t resist. You will have to contact shores because I believe you have a fault with your cappachino dispenser, possibly because it’s on the wrong side of bike.. (inside joke, correct answer should be coming soon)
Started by Horsehammerr, 23 hours ago
Started by scotcher65, 20 hours ago
Started by Doc_V, 9 hours ago
Started by McVinny614, 12 hours ago
Started by Lug Nut, 12 hours ago
48 responses
Started by Lug Nut, 07-22-2020, 05:21 PM
Started by Brabbit, 3 weeks ago
Last Post scotcher65
Started by marcus, 6 hours ago
Started by roadiemort, 3 weeks ago
142 responses
Started by Galcanised, 18 hours ago
Last Post MrG
by MrG
Started by Oldsguy1, 21 hours ago
Started by Shores, 1 day ago
Started by Father Pobasturd, 2 weeks ago
Last Post Chooch
by Chooch
Started by Ridenstar, 1 week ago
Started by Horsehammerr, 1 week ago
58 responses
Started by estrom, 1 day ago
Started by Doc_V, 1 week ago
Started by RRS_07RdStar, 1 week ago
Last Post JohnnyBGreen
Started by Mandostar, 6 days ago
