Carb Question with Pumpless System
    Yep need to know what size main jet and pilot jet is currently in the carb along with the needle clip groove setting
  • Blackbeard
    Sounds good. I'll try to get to it this weekend. Thanks for your help.
    Jet size remains the same. You should verify what jets exactly are in there as well as measure your float level and make sure you have the 3mm needle valve (I imagine you do or it wouldn't hardly run at all). Might as well clean it realngood while doing all of that.
  • Blackbeard
    started a topic Carb Question with Pumpless System
    Hi Y'all,
    So, I have a 2004 1700 RoadStar. It was converted to a pumpless system before I bought it. It has a MaxAir air filter/intake on it and RoadHouse pipes. Overall, it seems to run strong, but I'm not convinced that it is running "right." It sometime burbs out of the intake, and the idle drop seems to hang a bit when it's warmed up. I recently changed the plugs and adjusted the valves. I figured the next step would be to play with the carb. I haven't taken it apart yet, but the idle never changed when I turned the pilot from 0 to 3 full turns out, AND the engine never stalled with the pilot turned all the way in. I assumed the pilot adjustment was a fuel adjustment and not air, but I may be mistaken. Please let me know if I'm wrong there.
    Does the pumpless system require a different size pilot jet? Does the current pilot jet seem too large?
    Thanks in advance.
Started by mariner3302, 4 weeks ago
Last Post Jokke75
by Jokke75
Started by Lug Nut, 12 hours ago
Started by brianmac, 3 days ago
53 responses
Started by Lug Nut, 14 hours ago
Started by Shores, 2 days ago
Started by roadiemort, 08-22-2020, 04:09 AM
268 responses
Started by SbTx_Rider, 2 days ago
Last Post LeLimoMan
Started by Lug Nut, 10-18-2020, 05:32 PM
Last Post LeLimoMan
Started by scotcher65, 2 days ago
Last Post LeLimoMan
Started by Herrindude, 5 days ago
Last Post BubbaKahuna
Started by Doc_V, 1 day ago
Closed: RSC Decals by roadiemort
Started by roadiemort, 06-16-2020, 11:30 AM
58 responses
Started by Jokke75, 5 days ago
Started by Slammed&Cammed, 3 days ago
Started by brianmac, 1 week ago
Started by Tom_WSR, 5 days ago
Started by GreenMachine, 08-13-2020, 01:19 PM
272 responses
Started by brianmac, 2 weeks ago
45 responses
