Speed sensor
  • Speed sensor
    Anybody here changed the speed sensor?
    Any tricks?
    Looks like a bitch to change, the location of this could've been better.....
    Any tricks?
    Make sure the spedo needle isn't sticking to the stop post before changing that, I've heard of people puting a plastic or rubber sleeve over the post so the needle won't stick to it
      Pain in the ass to get ro...
      need a small ratcheting bit driver.....I removed seat and side covers...I cut down the bit as much as i could and supergfued it in so it wont back out. I used a paint stirring/ruler wooden piece to apply pressure on the back of the head of the bit driver to help with getting the bolt back in (removal pretty easy). New sensor is about $90
        Pretty sure it's not the actual speedo, as I've tried two different. Either sensor or wiring...
          If the odometer isn’t registering, it’s not the meter.
          • manser64
            manser64 commented
            Exactly
          As far as I have guessed the blue/yellow to the sensor is 12v+, the black/blue is 12v- and the white is signal. So I rigged it up with a + from the battery to the blue yellow, a - from the battery to the black/blue, but still no luck. Was this a too optimistic test? Had + and - to the meter simultanously, and the white of course
            Was the sensor. If you should ever find yourself in the same situation, then just don't. Knowing the speed you're travelling with is highly overrated!
            Lug Nut was right. Pain in the ass!
              What was the milage when it failed
                Around 35000 miles
                1,014 responses
                Last Post Ironman
                by Ironman
                Started by joe29, 1 day ago
                Last Post joe29
                by joe29
                Started by area1509, 18 hours ago
                Last Post RRS_07RdStar
                Started by Road Star Charlie, 23 hours ago
                Last Post scotcher65
                Started by Mr300game, 19 hours ago
                Started by McVinny614, 1 week ago
                89 responses
                Last Post rsokie
                by rsokie
                Started by roadiemort, 08-22-2020, 03:09 AM
                172 responses
                Started by Mr300game, 1 week ago
                Started by Cmw2212, 04-26-2018, 07:38 PM
                Started by Lifeguard, 2 days ago
                Started by Blackbeard, 2 days ago
                Started by Blackbeard, 1 day ago
                Last Post Blackbeard
                Started by estrom, 6 days ago
                Last Post Baxter85
                Started by JohnnyBGreen, 3 weeks ago
                Started by LUV4RS, 2 days ago
                Started by Sluggerknuckles, 2 days ago
                Started by jinxpress, 2 days ago
                Started by GreenMachine, 08-13-2020, 12:19 PM
                250 responses
