Oil pressure gauge install
  • Oil pressure gauge install
    Im looking to install an oil pressure gauge on the 07 roadstar 1700 . I've looked and cannot find anything on it . Mainly like where to tap in at that would give the most accurate reading . Found a few videos but nothing showing the actual process. Thanks in advance fellas.
    https://www.roadstarclinic.com/forum...pressure-gauge
      Mine is on the rear head oil line
        The port I used was a main port that feeds the left crank bearing, #1 connecting rod bearing, left starter/generator shaft journal, and the heads rocker arms. The port is just below the banjo fitting for the heads, and is machined for a m8 banjo fitting. I used a old head manifold line and cut the banjo fitting line where it starts to go 90 degrees at the tee. The line is 1/4", and I bought a premium stainless compression fitting to use on the oil gauge line. Using a piece of 1" aluminum strap as a support bracket, and studded the right bolt hole on the starter shaft journal cover. The 1.5", 0 to 100psi gauge is very rigid with the engine and is a Marshall liquid filled type.
ID:	60111Click image for larger version
ID:	60112Click image for larger version
        • Rob in FL
          Rob in FL commented
          That's a very professional install I bet you could sell those as kits
        What is your cold start pressure?
        Is the word PICTURE a picture?
          My gauge shows 70 psi during cold start up. I believe that's when the bypass is opened.
        • Jeaston
          Jeaston commented
          should be 80psi. And the oil gauge port is on the right side bottom of the engine. As per yamaha. Silver and black motors have two differant size fittings. But if your happy thats all that matters.
        Thanks a lot! I dig this setup ! Along with the detailed info Duke!
          is the bolt you tied into an 8mmx 1.25 bolt? And if so, how long was the banjo bolt you installed. I am ordering a gauge and a banjo nut to mount an oil pressure gauge like you did.
            At the port location that I installed the oil line to, it would be the same bolt as the oil feed line from the case to the heads. That banjo bolt is a 8mm x 1.25 thread x 22mm long.
              Thanks alot for the info, where can i find a 8mm banjo fitting to 1/4 stainless line like you used, thanks.
                Look at the information that Shores posted. (Thank you Steve.)
                I used the bottom bango M8 fitting part of a head oil feed line, cutting the line with a tubing cutter just below the bend at the tee. The line is 1/4" od, and using a premium SS compression fitting works perfectly to mount the gauge to the oil line. This allowed me to use a port on the case that feeds the crank bearings and put the gauge where it's mounted as shown. I Made a aluminum bracket to help hold the gauge rigid, using a stud and nuts to retain the bracket.
                Duke.
                Started by JimMoo, 1 day ago
                Last Post Lifeguard
                Started by boomerA, 6 days ago
                Started by Ahodge75, 1 week ago
                Started by Shores, 14 hours ago
                125 responses
                Started by DEEPHATE, 4 days ago
                953 responses
                Started by Lifeguard, 1 day ago
                Last Post Lifeguard
                Started by rox, 2 days ago
                Started by Jdd90, 3 days ago
                Started by boomerA, 3 days ago
                Started by Do Something, 6 days ago
                Last Post SuperG
                by SuperG
                Started by Neverdone, 6 days ago
                Started by Swampy, 1 week ago
                Last Post LawrenceTibbs
                Started by LawrenceTibbs, 3 days ago
                Started by Lifeguard, 3 days ago
                Started by cike, 03-10-2020, 04:32 PM
                Started by Road Star Charlie, 05-22-2019, 04:21 PM
                Last Post Road Star Charlie
                Started by Neverdone, 5 days ago
                Started by roadiemort, 3 weeks ago
