Engine Oil bolt
    Been using my jack since the bike was new, not a POS like some are and strap the bike once you have it in position. I don't like laying on the floor anymore lol.
    I don't use a lift for any fluid changes....hate working on a bike when it's in the air on a motorcycle jack. If I have to lift it up input jack stands under it ...much sturdier ...
    Like previously said get a new crush washer or fine sand that one down flat . Looks like you were leaking from the washer. There are those that replace the crush washer every time and there are those that are careful and reuse it for a lifetime.
    Thin wall Snap-on socket works too.
  • Purplestar
    Thank you all for the support and helpful answers, after 2 hours and a half I was able to get it off. Thank you
    New plug and crush washer torqued to factory specs, use any wrench you want as it won't leak or be over tightened for the next time. Too easy right?
    I use my bike lift and a long 17mm wrench.
    i agree
  • YZ18
    Don't use a 12 pt wrench...just a 6 point
    Ok that's cool! I cut off a perfectly good standard length wrench.
    You don't have to roll it up on anything or use a jack. You just need a short wrench that you can get in there and tap with a hammer.
  • Shotround
    knowing me, this will happen if i try rolling it on anything. any other alternatives short of a proper lift?
    Posted wrong link that was 12 point! Want 6 point 17mm stubby box end wrench
    Short "stubby" 17mm box end wrench
    When you drain the oil, you need to remove two bolts. One as seen your photo and another at the right rear under the oil tank. Don't just do one or you will only be draining half of the oil. I just use a modified 6 point box wrench or open-end wrench with a shorter handle. Roll the bike up on a couple 2x4s and put a 2x4 under the kick stand. Then gently tap your modified wrench with a hammer. Be sure to replace the crush washer.
  • Purplestar
    started a topic Engine Oil bolt
    Engine Oil bolt
    Is there a specific way or tool to get the engine oil bolt off? I am unable to screw this off. It looks like the top base is on the way,
1,316 responses
Last Post Mr. Miyagi
Started by joej85a, 2 days ago
Last Post Dr. D
by Dr. D
Started by Lug Nut, 20 hours ago
Last Post EasyTargetRN
Started by DWD6955, 5 days ago
Started by bigjames, 2 days ago
Started by ItBeMe, 1 day ago
Started by Snotrub, 2 weeks ago
Last Post DWD6955
by DWD6955
Started by Mr. Miyagi, 2 days ago
Started by [email protected], 2 days ago
Started by Jwojtt, 1 day ago
Started by MikeyC, 07-11-2022, 11:19 PM
Started by Lug Nut, 4 days ago
Started by Hairless Hippy, 1 week ago
Started by brianmac, 4 weeks ago
Started by Roadstar_Rob, 6 days ago
Last Post 6door7r
by 6door7r
Started by Der Steppenwolf, 5 days ago
Started by ebaleytherogue, 04-22-2019, 11:08 AM
Last Post JJansen
by JJansen
Started by CHEAPOMCGEE97, 3 days ago
Last Post Shotround
