Rear wheel collars?
    I knew I could depend on you Ken. That's what I did. Thanks
    The black end spacer is a little smaller on the seal side and goes to the brake rotor side, and the silver one is a little larger sealing face, going to the hub seal pulley side.
    The spacing is the same for both spacers, but the sealing diameters are a little different.
    You would only be able to see the flange of each spacer and maybe the color but you would not be able to see the outer diameter or length. I put it all back together before I realized that I didn't inspect them again but I believe they are the same size, just a different color.
  • Mr. Miyagi
    Shores, would I be able to look at the back of my '09 and see what you are talking about? Now remember I have a knee that I can't bend and I have trouble getting down on the ground.
    started a topic Rear wheel collars?
    Rear wheel collars?
    I’ve installed my rear wheel many times but can’t remember if the two final/outer collars & are the same. The right one I believe is black and the left one is silver and it seams like I found them to be the same before but didn’t check this time. I’m anal about perfection. I know the part numbers are different. My 2008 may be different than older carbonated Roadstars.
    https://partstream.arinet.com/Mobile...nLopLHjU1.html
Started by Aussiestar, 1 day ago
Last Post SbTx_Rider
Started by ElVispo, 1 hour ago
Last Post ElVispo
by ElVispo
Started by Aussiestar, 23 hours ago
Last Post Aussiestar
Started by WobblyBoot, 8 hours ago
Last Post MidnightRide
Started by Kmartcivic, 2 weeks ago
Last Post WobblyBoot
Started by JHouse, 3 weeks ago
Started by MidnightRide, 1 day ago
Started by tekdiver609, 02-03-2019, 07:49 PM
Last Post Azuqui
by Azuqui
Started by WobblyBoot, 16 hours ago
Started by Renegade, 2 weeks ago
Started by Mr. Miyagi, 1 day ago
Last Post KFallsRider
Started by WobblyBoot, 3 days ago
Started by rsnyder1976, 2 days ago
Last Post rsnyder1976
Started by Do Something, 4 days ago
1,264 responses
Started by Leadkrm, 01-10-2019, 06:28 AM
Started by Apsn, 1 week ago
Last Post Tcontrol
Started by marcus, 2 days ago
Started by roadiemort, 04-17-2022, 01:19 PM
37 responses
Started by scotcher65, 2 days ago
