No fuel light
  • Flashback
    It's a common symptom when going pumpless. especially if you ride a lot of hills. If you have to see the light then cutting the petcock feed will fix it.... or put the pump back on
    I'm a "I see the cup half full" kind of guy. Plus, I'm old school. I look in the tank if I need to check fuel. Even when my fuel gauge was working, it wasn't very accurate.
  • Coach
    Yes, the good thing it it’s not!
  • Spydr
    Hmmm... This has me scratching my head.
    Hopefully someone will offer a solution for you.
    There's a great bunch of guys here. They'll help you to figure it out.
    I would be surprised if it had anything to do with going pumpless. It didn't affect mine when I did it. Even when my fuel gauge isn't working (pretty much all the time lately) the low fuel light still works. I wish you the best of luck figuring it out. At least it's not something stopping you from riding.
  • Coach
    Spydr. Yes the light it’ is working
  • Coach
    Hey Daveto, no I didn’t cut the tubes down.
    Thanks for the reply
  • Spydr
    It's most likely your sending unit inside the tank.
    Does your low fuel light Ever come on?
  • daveto
    Did you cut the inlet tubes down on your petcock? That’s how most remedy your concern, or keep it on reserve.
  • Coach
    started a topic No fuel light
    No fuel light
    Since going pumpless my low fuel light won’t come on when needed. I ride with the petcock on on and get surprised when I have to switch over to reserve. Is this a symptom of going pumpless or do I have something else going on? It did come on before I removed the pump. 03 1600.
    thanks
75 responses
Started by WarPig, 5 hours ago
Started by Oldsguy1, 2 days ago
Last Post Oldsguy1
Started by Blackcloud12, 07-27-2020, 10:42 PM
47 responses
Started by Lug Nut, 3 hours ago
Started by Doc_V, 1 day ago
Started by Pauli466, 1 day ago
Started by Roadtalker, 9 hours ago
Started by Horsehammerr, 2 days ago
Last Post Paladin
by Paladin
Started by Pauli466, 11 hours ago
Started by Tsilk87, 11 hours ago
Last Post MrG
by MrG
Started by Shores, 02-21-2018, 08:16 PM
Last Post universes
Started by McVinny614, 2 days ago
Started by Shores, 3 days ago
Started by MrG, 1 day ago
Started by Shores, 1 day ago
Started by Lug Nut, 07-22-2020, 05:21 PM
143 responses
Started by scotcher65, 2 days ago
