Roadwing suitable gauge
  • Roadwing suitable gauge
    Has anyone had luck hooking up a gauge to their roadwing shock upgrade? If so could you share?
    I believe that was done or at least attempted by just a couple people when the roadwing first come out. You would have to try and find in in the old RSC archives. I think it wasn't popular because it is pretty meaningless. I have a Rap on mine and it has an indicator on the side of it. In most cases the shock is a "Set it 1 time and forget it. at least mine was after I installed the Rap. My pump had a tendency to lose pressure so it always needed adjusting so I replaced it with the Rap. If you are using an electric pump and want to adjust it from 1 up to 2 up riding just hit the switch until it feels good.
    • Sguitard
      Sguitard commented
      I was thinking of going with a RAP, but they are hard to come by in Canada/Ebay. my thoughts on installing some sort of display was to prevent bottoming out the pump in either direction.
      Bottoming out on the stiff side shouldn't be an issue. There was a fix for bottoming out on the soft side to keep the pump piston from coming off the worm. I don't remember for sure but I think it involved putting something under the piston it to keep it from being able to unscrew far enough to separate.something like a thick pc of rubber I would have to find my old pump and take it apart to see what I did to it.
    jonsie hooked up a voltage gauge to the sensor on the motor and he could tell where the pump was based off the voltage.
    Started by kwarten, 6 days ago
    Last Post giostar
    by giostar
    Started by Nalla, 04-10-2020, 02:45 PM
    Last Post AzTank
    by AzTank
    Started by NCB, 23 hours ago
    Started by twowheeltherapy, 2 days ago
    Started by daveto, 23 hours ago
    Last Post daveto
    by daveto
    Started by Grease, 03-04-2019, 08:08 PM
    43 responses
    Started by Jaybo, 2 days ago
    Started by Angel220, 2 days ago
    Last Post Angel220
    Started by Airlordd1, 1 day ago
    Started by Pauli466, 4 weeks ago
    Started by Zachhaynes922, 5 days ago
    Last Post Zachhaynes922
    Started by curtixman, 6 days ago
    Last Post highvoltage
    Started by cap-tech, 3 days ago
