Belt alignment
  • Belt alignment
    I tightened the belt to specs and now my belt rides to the right, brake side. Before I did the belt was in the center. My question is to bring the belt to the left would I tighten the right adjustment?
    thanks
    Make sure the alignment of the wheel is the same on both sides and don't worry about where the belt rides.
    • Coach
      Coach commented
      Ok great. Alignment is perfect. Thanks Dave
    Don't trust the alignment marks on the swing arm, they are notoriously wrong. Measure from the center of the swing arm pivot to the center of the axle.
    • Coach
      Coach commented
      Thanks FP, got it on the money
    Mine is slightly to the right on the rear pulley and slightly left on the front one but not against the flanges on either. The belt will move to the opposite side of whichever bolt gets tightened, loosing will send it to the same side
      Balancing act between belt location in pulley and proper belt tension. I always spend 15 or 20 mins fine tuning this and gets near centre but not always which is good for me.
      165 responses
      Started by Knutselsmurf, 1 day ago
      Last Post Knutselsmurf
      Started by RoadieRob, 22 hours ago
      Last Post RoadieRob
      Started by Pauli466, 22 hours ago
      Started by ctkog, 19 hours ago
      1,347 responses
      Started by Sguitard, 4 days ago
      Started by Aussie John, 1 week ago
      Started by 2time, 1 day ago
      56 responses
      Started by coreys1982, 3 days ago
      Started by LUV4RS, 5 days ago
      Started by Cubo55, 5 days ago
      Started by MikeyC, 4 days ago
