Oil Pressure
  • Oil Pressure
    Do I need a 100 lb. pressure gauge or will a 60 lb. work ? my gauge face is so blured out that its nearly impossible to read.
    SS custom cycle uses 100lbs oil filled.
      60# will be more accurate at lower pressure (at idle & after the oil is warm)
        You don't think startup pressure will damage the gauge ? I bought a Marshall 60#
          It could. Depends on what bellows and gearing Marshall is using.
          When my bike first starts, oil pressure is around 80 psi + on high idle, hot high idle is around 50 +.
        Get the 100 to avoid damage to the gauge. Also make sure you buy the proper sending unit for the gauge that you buy. It does make a difference.
        • TimB
          TimB commented
          Sending unit? Mine mounts directly to the head, no sending unit
          your is a mechanical gauge. mine is electric gauge mounted in the fairing and uses a sending unit. either way is fine.
        Tried the 60# , Screwed it. 100#er going on today.
          80lbs when cold. 8lbs when hot at idle. The oil pressure port is on the right side bottom aft of the cams. Black or silver motor ? It matters.
          This space intentionally left blank
            100# Gauge works Great
            Started by Doc_V, 20 hours ago
            AOC by Shores
            Started by Shores, 5 hours ago
            Last Post WasHD
            by WasHD
            Started by Danman1995, 2 days ago
            Last Post Danman1995
            Started by Kenkaman, 3 hours ago
            Last Post midnitmike
            Started by Kenkaman, 7 hours ago
            Last Post mbk
            by mbk
            Started by Father Pobasturd, 9 hours ago
            Last Post mbk
            by mbk
            Started by Scjpll, 7 hours ago
            Started by Jonathan, 6 days ago
            Started by Kenkaman, 22 hours ago
            Started by midnitmike, 3 days ago
            Started by AR. Hillbilly, 23 hours ago
            Started by AreikUSA, 1 day ago
            Started by zingpow, 23 hours ago
            81 responses
            Started by Rodzim, 1 day ago
            Last Post Rodzim
            by Rodzim
            Started by bigguyokie, 01-02-2019, 12:04 PM
            84 responses
            Last Post bigguyokie
            Started by Marc1986, 1 day ago
            Started by Rob in FL, 08-24-2018, 09:38 AM
            103 responses
            Started by JoeBloShmo, 1 day ago
            Last Post AreikUSA
