Front Brakes
  • Front Brakes
    Put a new front tire on yesterday. Noticed Left side Brake pads a little cocked. Pulled the slider pins and they were DRY. Cleaned and greased all four and now I'm having a jerking , grabbing issue. What can be causing this ? Pads only have 1000 miles on them and are evenly worn.
    The hand lever uses a screw that pushes on a flat surface into the master cylinder. A hole will wear on the flat. That could be part of the issue.
    Peace,
    (But you can call me Joe)
      When was the last time you replaced the brake fluid?
      My bike was doing the same thing as you described. I flushed and replaced the fluid, and all is well now.
        Both, do both... the lever pushes against a flat surface, that wears some. Give it some lube... and, I never experienced a more dramatic improvement in braking, than when I did a fluid change. Had no idea it could help so much!
          The brake fluid holds moisture, which lowers the boiling point. You can boil in one piston or caliper and not the other and get very uneven feel. I flush my brake fluid clean once a year. Also agree with the master cylinder plunger grinding on the adjustment screw head. Been there.
          Started by dwilli, 3 hours ago
          Started by BloodMoney, 1 day ago
          Started by Aflion, 1 day ago
          Last Post Littlebull
          Started by ItBeMe, 1 day ago
          Started by 07Roadstar, 02-28-2018, 02:46 PM
          Last Post chess
          by chess
          46 responses
          Started by 07Midnight1700, 1 day ago
          Started by Blackbeard, 01-06-2019, 09:48 AM
          Started by 07Midnight1700, 2 days ago
          Last Post 07Midnight1700
          Started by Ronin325i, 1 week ago
          Last Post Ronin325i
          Started by Matty1, 4 days ago
          Started by Lug Nut, 4 weeks ago
          Started by Debevec, 3 days ago
          Started by Tomtom123, 4 days ago
          Started by Mc765, 3 days ago
          Last Post Gwhiz
          by Gwhiz
          Started by Jammin'John, 4 days ago
          Started by 08BlueRoadStar, 3 days ago
          Last Post Debevec
          by Debevec
