Front Brake stiffens in heat
  • Front Brake stiffens in heat
    On the ride home the last few days I've noticed its been hard to pull the front brake lever in. It been hot here in the PWN the last few days, and I notice that when I headed to work in the early AM nits not bad, but after sitting in the sun all day when headed home around 5pm the brake lever tends to be harder to pull (stiff) Been thinking about swaping the brake fluid out, but not sure this is gonna help. Wondering if anyone else has experienced this, and If so how they fixed it.
    Thanks
    My Garage: https://sites.google.com/site/my2007roadstaradvancers/
    You Tube Videos: http://www.youtube.com/c/ClownsRoadstarAdventures
    Change the fluid & don't overfill the M/C.
      Also lube the lever and plunger. Make sure the linkage is not touching the exhaust and transferring heat to the master cylinder.
      signature
      • daveto
        daveto commented
        If your front master cyl is touching your exhaust you may have something bigger wrong with your bike.
      If you haven't changed the fluid in some time... you might be amazed at the difference. Every old Road Star we've been changing the fluid out of has resulted in a pretty dramatic improvement in brake feel and performance! Try that first.
        My bad, I was thinking of the rear MC.
        signature
        • daveto
          daveto commented
          We know, and that is great info. I was just yankin yer chain while I had the chance.
        Thank you all for the advise, I'll change the fluid this weekend Thanks
          +1 on brake fluid. Brake fluid is very hydroscopic and absorbs water from the atmosphere. The more water in the fluid the lower the boil point and the worse it is for brakes.
          Started by Father Pobasturd, 8 hours ago
          Started by 03LiquidSilver, 3 hours ago
          Last Post 03LiquidSilver
          Started by Beaker13, 8 hours ago
          228 responses
          Started by zingpow, 12 hours ago
          Started by YZ18, 6 hours ago
          Last Post YZ18
          by YZ18
          Started by viking, 11 hours ago
          Started by jamez1965, 7 hours ago
          Started by darkstar, 6 days ago
          Started by Doc_V, 6 days ago
          Started by Laidback, 10 hours ago
          Started by Cthom32, 1 day ago
          Started by tyates007, 1 day ago
          Last Post Jeaston
          by Jeaston
          Started by zingpow, 03-20-2019, 11:59 AM
          65 responses
          Started by Father Pobasturd, 13 hours ago
          Started by Doc_V, 1 day ago
