Crappy fuel mileage
  • Crappy fuel mileage
    I have a 2000 1600. The PO installed a BAK, V&H Longshots and the carb was jetted. I haven't changed anything in the carb but I am getting consistently lower fuel mileage. In the 26-30 range mostly towards the bottom end. I don't ride over 65 very often.
    I pulled the carb to check the jetting and one says 170, one says either 37.5 or 57.5 and I think it has a square on it.
    Check out the post below "Carb Jetting" give you some ideas
      Dirty air filter?
        I am cleaning that today. I pulled the carb last night to take a look inside. I just recently started getting fuel overflow after she had been ridden for a while and then turn the key back on.
          Don't fool with it... think about this: That carb is 18 years old. Do a complete cleaning and rebuild. Spend a little money on it. There are plastic and rubber parts that just get old and go bad. That thing has to work in a gasoline environment all the time. Go right through everything and RE-NEW it. You'll be so satisfied with the result.
            Your jetting should be fine. Are you bumping the rev limiter in 1st or 2nd from time to time? The 170 Main is fine with a 4250 rev limit, and the bees knees, with a higher rev limit of 4750 or 5000rpms.
            The Pilot is a 37.5, and the square lets you know they’re Mikuni jets.
            The carb puke, is often heat related, but can also be a result of a bad seal with the needle and seat. If it’s the original, then at 18 years the oring that seals the seat half in the little hole it resides in, is probably letting fuel past.
            I suspect the fuel pump is still on the bike. They only exacerbate the whole carb puke issue. It’s a flaw in the design. Ethanol treated fuel makes it worse.
            The crappy fuel mileage is typical of a failing seal at the needle and seat. I’d definitely change it out. With your jetting and riding style, you should easily be in the mid 40’s.
            If you turn the fuel off at the petcock about 30 seconds or so before you turn the key off, and turn it back on after you start the bike the next time when riding in the hotter weather, the puke related to the fuel pump, will be taken care of. I always turn the fuel off before I turn the key off anymore anyway. I let it run a bit with the fuel off, not necessarily to drain the bowl, but just a bit to lower the fuel level in the bowl and drop the needle out of the seat.
            Run something like Techron, Seafoam, or MMO in your fuel. I add a couple ounces every other tank, just to keep things clean.
            • Cmw2212
              Cmw2212 commented
              I do have a dyna box on it. Would that give it the higher rev limit?
              I thought I replaced the needle and seat last year during the rebuild but can't remember, chemo treatments didn't help my memory. That is one reason I pulled it apart to verify I did it. I do still have the fuel pump but have been thinking of going pumpless.
            It was running pretty well but I have never seen or heard a properly running R* to compare it to.
            My last bike was a Vmax and prior to that a couple of R1's so nothing to compare apples to apples.
              If you have a dyna3000, then the rev limit is probably set at 5000. That’s great. The 170 Mikuni Main will work perfect with it.
              If you’re not sure about the needle and seat, then I’d be tempted to do two things. Properly check the float level, and if that looks fine, then either replace the needle and seat with OEM, or go pumpless, and switch to the larger gravity flow.
                OK pulled it apart and the seat looks like crap so that may be where some of my overflow is coming from. Also the 2nd jet is a 57.5 with an R and a square with another square in it. The needle looks like it is the 5th groove from the blunt end with one metal washer and a plastic washer beneath and one metal washer on top.
                  It should be a 37.5 on the pilot jet and you should be in the 4th groove. A nasty needle and seat is going to run you high on float level, using too much fuel, and being on the 5th groove you are too far up the needle and putting too much fuel through there as well. I run the 170 main with the needle in the 4th groove and no added shim. Gets 41-43 mpg in normal riding, but I can get 48 out of it putting around at 60 and below. Sounds like you are on the right track to correct your high consumption.
                    What is the deal with the 57.5 jet? Anybody ever hear of that?
                      If you look closer I think you will find that 5 is a 3
                    I originally thought it might be a 3 but after getting the magnifier out it looks like a 5 not a 3.
                      That’s not the Pilot jet. It’s the Starter jet. The Pilot jet is the tall thin one off to the side. Put that back where you found it.
                        OK the tall thinner one doesn't have anything on the top and the other one only has 170.
                          As it should be. The Pilot jet has its size written on the side. You won’t be able to see it, until you remove it.
                          You’ll need the glass again. It’s small.
                            OK I will check it tomorrow. I am going to look up the part numbers for the needle and seat and hopefully I can get them by Friday.
                              I think I'm in the same boat as you with the mileage. Only had the bike over a week now and today just calculated what I got on my last tank. Roughly 28 mpg. I should clarify though that this is on 2006 and mine is a 1700 with D&D pipes and Baron BAK. I'll have to track it a bit more to confirm on this next tank. But like SKWEARpeg said, I'm using MMO in each tank to try to clean up any neglect from the previous owner. When I get some time I'll have to pull the carb to verify the jetting and overall condition of it.
                              I just cleaned a very dirty air filter and recharged in last week with the K&N kit. But also getting an oil mist that sprinkles onto my exhaust pipe and oil runners (I think) which seems to be coming through my BAK. Must be pushback from the vent/overflow tube that whets the air filter than sprays the mist through it while riding.
Name:	Oil spray.jpg
                              Shiny Side ⬆︎ Rubber Side ⬇︎
                                Originally posted by Mark_N View Post
                                .......I just cleaned a very dirty air filter and recharged in last week with the K&N kit. But also getting an oil mist that sprinkles onto my exhaust pipe and oil runners (I think) which seems to be coming through my BAK. Must be pushback from the vent/overflow tube that whets the air filter than sprays the mist through it while riding.
Name:	Oil spray.jpg
                                No, this is likely because you over oiled the filter. Very easy to do...I’ve done it. Ride it like you stole it for 50 miles or so to blow out the excess KN recharge oil. I had a friend last week who was complaining of decreased mileage after the dealer recharged his Stratoliner filter. I told him I suspected the same problem and sure enough after a few miles his mileage returned to normal.
                                  What Shores described is pretty typical of an over oiled filter.
                                  Another thing I wonder is if the crankcase vent is still connected to the back of the BAK. It’s a vent line that runs from the front most connection on the top of the rear rocker cover, to the back of the air box.
                                  Take a look at that. If the vent line is still routed there, you will want to relocate it. The crankcase vent, is where the blowby from the crankcase exits the inside of the motor. That oil vapor, will over oil your air filter, all by itself.
                                    Yes, it is still there. I plan to relocate it. Noticed the little tube when I took off the BAK to clean and recharge it. Couldn't find a clear picture of it in the service manual but I figured it was just the vent tube. That also was making the inside of the air box rather oily when I first got in there to look at it and clean it. But the previous owner had the bike filled with 5.5 quarts (yes, 5.5) of oil so I didn't know if the excess was contributing to the problem.
                                    3,304 responses
                                    Last Post Jaskin71
                                    Started by Doc_V, 3 days ago
                                    Last Post Rodzim
                                    by Rodzim
                                    1,023 responses
                                    Started by tyates007, 3 hours ago
                                    Last Post Moser39
                                    by Moser39
                                    488 responses
                                    Started by D-Fresh, 8 hours ago
                                    Started by Horsehammerr, 4 days ago
                                    Started by eardog2, 1 week ago
                                    Last Post Grnhornet
                                    Started by grubsie, 2 days ago
                                    Started by Mitch82, 1 day ago
                                    Last Post TimB
                                    by TimB
                                    Started by gary1717, 07-12-2018, 05:40 PM
                                    Started by LDofDC, 04-15-2018, 07:21 PM
                                    54 responses
                                    Last Post bigguyokie
                                    Started by Spydr, 2 weeks ago
                                    Started by Jaskin71, 1 week ago
                                    Started by Herrindude, 2 weeks ago
