Dead phase 7?
  • Dead phase 7?
    Anyone else had a truck lite headlight just die? Worked fine last night. This morning I went to leave and it flickered dim on low and went out on high.
    I had a regular bulb that was inop and when I went to replace it I found the plug melted. Before you get a replacement you should check the factory headlight connector. I have seen guys on here reference a ceramic plug that should last, I just installed another plastic plug I had laying around.
      Was in there already to check the connection because I had it out last night. Plug was fine.
        i've been running mine for about 5-6 years without any problems,,,, the bike prolly said. "hey, if I get new paint I want a new light too"
        Check the fuse... maybe you pinched a wire somewhere putting everything back together.
          Volt meters tell the tale.
            Took it back apart when I got done working and found the ground wire on the light side had come out of the plug. When I moved it around more it fell out. Pushed it back in and reconnected the plug and all is well
            Started by coolalexrex, 2 days ago
            Started by Russo, 2 hours ago
            Started by LittleMike52, 5 hours ago
            Started by YZ18, 21 hours ago
            Started by Dick M, 21 hours ago
            Last Post moose
            by moose
            Last Post coolalexrex
            Started by 04RoadStar1700, 4 days ago
            Started by Sparker, 4 days ago
            Started by Jrose2118, 1 week ago
            Started by Sharpman66, 3 days ago
            Last Post Sasquatch
            Started by Duke, 2 days ago
            Started by Dwizzle6123, 1 week ago
            Started by LittleMike52, 3 days ago
            Started by Jaybo, 04-04-2021, 09:38 PM
            40 responses
            Started by Papi, 5 days ago
            Last Post 129drifter
            Started by Father Pobasturd, 04-05-2021, 10:46 AM
            Started by jimlun, 4 days ago
            Started by Chefturner, 07-01-2018, 11:12 AM
