Dying on the run
    have you checked or removed the screen that is located in the carb inlet tube. It is a little screen with a plastic type lip holding it in the inlet of the carb. you have to take the rubber fuel line off the carb side to see it. it actually looks like part of the carb. the screen is very fine and wouldn't take much crud to impair fuel flow. if it. if it hasn't already been removed go ahead and remove it.
      i will check the bowl and the screen tonight when I get off. this is definitely a head scratcher. I appreciate all yalls input
        yes its a head scratcher. I had the same thing happen to mine back in the early spring. I asked all the same question, got the same answers , its in the Forum somewhere. I replaced everything I could think of or buy parts for. electrical and fuel.. Finally I gave up and decided to take to the dealer. The day I took it, it ran fine (go figure). It stayed at the dealer for 3 weeks they couldn't find anything. after having it 3 weeks I said I'll come get it. Well long story short, it hasn't done it again. I even took it on a trip from South Carolina to El Paso last summer. Not even a hiccup. rode in the rain, rode in 105 heat even rode it 1100 miles straight from Ft Worth to Columbia SC Iron Butt saddle sore 1000 in 19.52 hours . haven't had a problem since. Don't know what it was or if something I changed fixed the problem but it didn't work then it did. I feel your pain !!
          To be clear, when you remove the float bowl, you need to inspect the float needle *tip*. It's rubber and can become worn over time causing it to stick in the whole, preventing enough fuel from filling the float bowl quickly enough. The wear can be as little is this:
          Started by backinthesaddleagain, 1 day ago
          Started by Tcontrol, 2 hours ago
          Started by zingpow, 1 day ago
          3,695 responses
          Last Post Milkman
          by Milkman
          Started by slyguy, 1 day ago
          Last Post Cheapa$$jimmy
          Started by Chief_10Beers, 4 days ago
          Last Post Carpetbagger
          Last Post RAFAŁ
          by RAFAŁ
          Last Post RAFAŁ
          by RAFAŁ
          Last Post Jed Milhorne
          40 responses
          Last Post fastjohnny
          Last Post zingpow
          by zingpow
          206 responses
