I have a set of V&H Longshots from a 1600 that I want to put on my 2009 1700. Looking for info on what size 02 sensor bungs (mm size) I need and where to get them so I can weld them onto the V&H pipes.
02 sensor bungs
Originally posted by Spydr View PostI'm about to add an AFR gauge to my 1700 soon. When I find out what size the sensor needs, I'll post it.
Someone else may post an answer sooner though.
Welcome to the New & Improved RSC!
Thanks davej.
Originally posted by davej View Postyou could have drilled a hole and just welded the correct size nut onto the pipe.
Originally posted by davej View PostAlso make sure you weld them in the correct location so that the wires are long enough to plug in without making an extension.
The rear would have had to be located on the top of the header pipe to plug in comfortably. I didn't like the look so I drilled the pipe near the bottom at a downward angle towards the bottom of the engine so it didn't stick out like a sore thumb. I already extended the wires on the rear sensor 4" to be able to reach the plug. This way, the sensor is not visible unless you intentionally look for it.
Curious though, should I use some type of sealant on the threads when I put the sensors in for good?
Got the bungs welded on and getting ready to mount the Longshots on but it will have to wait until I get back from vacation in 2 weeks. I have been thinking about a way to rubber mount the exhaust to the rear support to help reduce vibration to the frame. Has anyone else done this? if so, how you did it? Pros/cons with this approach?
Started by Shores, 22 hours ago
by EP Roadie
30 minutes ago
Started by JBones, 12 hours ago
4 hours ago
Started by Jclevesque, 06-02-2018, 11:19 AM
5 hours ago
Started by choppa, 5 days ago
by JBones
11 hours ago
11 hours ago
Started by Hank1988, 2 days ago
by JBones
11 hours ago
Started by Chooch, 12-05-2020, 10:49 PM
by JBones
11 hours ago
Started by Dan58, 1 day ago
by Ahodge75
12 hours ago
by EnergyGuy
14 hours ago
14 hours ago
by Pauli466
14 hours ago
14 hours ago
Started by Smokescreens, 1 day ago
15 hours ago
20 hours ago
Started by Blackbeard, 1 week ago
by Blackbeard
21 hours ago
Started by MrSinister, 12-06-2020, 08:54 AM
by MrSinister
Started by BrokenWheel, 2 days ago
by EP Roadie
Started by Rick Fortner, 3 days ago
Started by AR. Hillbilly, 02-01-2020, 11:31 AM
171 responses
Started by LDofDC, 4 weeks ago
79 responses
by EnergyGuy
