How to use Seafoam properly
  • How to use Seafoam properly
    What is the proper way to add seafoam into the gas tank on a Yamaha road star? The bottle tells you how much to add but it doesn't tell you actually how to do it. On a cold engine? Hot engine? Or can I just add it while the bike sits overnight?
    Can instructions are right on, only takes a little for routine cleaning.
    When my bike has been sitting for months I'll dump 1/4 to 1/2 can into a full tank of fuel as a 'shock treatment' to eliminate as much water from the system as possible.
    Does no harm and it blows all the boogers out pretty well.
    YMMV
      "Don't think too much, you'll hurt the team!"
        Hot, cold, doesn't make any difference. You're adding it to the gas tank. It makes it's way thru the fuel system as you run the engine. Just add it, run thru the tank of fuel, and then refill the tank. Repeat seafoam if you wish, or skip a tank and then treat. Doesn't matter if the bike sits overnite, or sits for a month.
          seafoam is just another gimmick additive, oil and glycol/alcohol. the new STP, techroline by exon is a better cleaner, use non ethanol gas and preservative for extended stays.
          • DEEPHATE
            DEEPHATE commented
            Seafoam is good stuff. That "gimmick" has been running almost 100 years strong. Just saying...
          Remember brianmac STP "is the racers edge"...
          665 responses
          Started by Roadrider, 3 weeks ago
          Last Post TorontoRoadie
          Started by TorontoRoadie, 15 hours ago
          Started by Kmartcivic, 1 day ago
          Last Post GreenMachine
          1,508 responses
          Last Post Zimasfriend
          Started by FuryGuy, 5 days ago
          Last Post FuryGuy
          by FuryGuy
          Last Post Dogbone
          by Dogbone
          Started by kragos, 5 days ago
          Started by ItBeMe, 4 days ago
          Started by Ben, 3 days ago
