Output shaft seal
  • Output shaft seal
    2002 Roadie chopper- had issues with the wide tire conversion, BMS offset pulley stripped the output (belt) shaft and had to replace. Took case apart on other side and found (thank God for Ebay!) another shaft. I didn't replace the seal on the pulley side, couldn't figure out how to get it out. Now I gotta replace, started leaking. Any tips on removing?
    Thank you guys!
    Be safe and God's speed​
    A dental pic works..hook the rubber and jiggle ..sometimes an old seal becomes the sacrificial lamb after all you’re replacing it….the O’ring (23) is usually the culprit for leaking
    Click image for larger version  Name:	7EF744D2-1495-4EFD-8FDD-26F132C397B0.png Views:	0 Size:	712.0 KB ID:	149374
    2009 Roady
    2009 Stratoliner S
      Did you make sure to put the thin O-ring on the shaft a head of the spacer collar?
      Started by Chrominator, 4 hours ago
      Started by Gutterpig, 7 hours ago
      Started by Darkkill57, 6 hours ago
      Started by Dave377, 5 hours ago
      Last Post Dave377
      by Dave377
      59 responses
      Last Post Ciccone1234
      Started by Brad_G, 23 hours ago
      Started by NCB, 5 days ago
      Last Post Kurf
      by Kurf
      Started by Mussky, 1 day ago
      Last Post ACEMUSTANG2002
