Help!
started on the barons jetting tonight all going ok until I pulled the plastic plug out to get the needle out..
the needle that was in was perhaps a dynojet needle. Anyhow, put new needle in following ‘DaveJ’ specs, but when I went to put the plug back in to retain the needle, to my dismay I found that 2 of the four plastic clip type holders had broken at the base..
my question is this.. is there a work around for this problem please?
Anyone and everyone please chime in all advice welcomed
Btw everything else such as the diaphragm are ok, bit of carbon build up on the slider that was easily cleaned and it slides fine with no wear marks noted on the slider
kev
kev
