dis-assemble the starter motor and clean and inspect it for worn brushes and broken holders. It is one of the more common issues.
the engine can hardly turn, starter testet
I'm also still leaning towards the compression release. After watching the video's, it sounded like, to me anyway, that it wasn't turning over fast as it should even with the plugs out. Maybe someone else will concur. Y'know, I have wondered if it would be possible to rig up a manual compression release, ala old school 2 stroke dirt bike? Take the electronics out of the equation. But then, I have also dreamed of magneto ignition and a kick starter. This is how my old '49 H-D EL Panhead was set up. So simple, so dependable, no need for a battery, had like, 6 wires on the whole bike. I could kick start that bike with my hand. Of course, it was really low compression and would only run around 80 mph tops. I think it would be really cool to set up a RS like that, and I will, soon as I win the Powerball.
Hello again.
had the cam out again to check the marks sat as they should.
I had to turn it a bit when I took it apart, so I'm a bit doubtful if it sat correctly.
but got it assembled as shown in the pictures without moving anything.
it actually seemed like it hurt a little when I drove the engine around.
I will work on it today and will come with an update later.
4 Photos
You have indexed it correctly… we are still concerned about the decompression solenoid… leave spark plugs out and activate the starter.. the core pin should push the spoon out about 5-6 mm… does this happen..??
Other concerns regarding the starter… have you dis-assembled and cleaned all the old brush dust from it… most people will polish the commutator (the copper part of the armature which the brushes make contact with) using a 600-1000 grit wet/dry sandpaper… use compressed air and contact cleaner to remove your sanding dust… make sure that you remove all residue from the commutator grooves between the copper plates.. inspect the brush plate for cracks… and reassemble..
The battery cables are also know as a weak link… most people will replace due to age and corrosion… many believe larger gauge cables help… a member here makes a replacement set using larger gauge wire… highly recommended… and of course cleaning the frame ground connection…
<<Father Pobasturd
I have to apologize for my bad English. but hey sounds like you should go out and get some pussy because you're in a bad mood.
good luck with that, otherwise it can be bought if you're unlucky.
Best regards from Denmark>>
LMFAO....EPIC! Gotta love it! Good luck with the bike, hope you will be cruising down the road soon.2005 Road Star 1700
2019 Kawasaki Versys 1000
2016 Kawasaki Versys 650
- Likes 1
Not sure what happened to our OP…. Did he solve his problem?…. Did we offend him..? Did he give up and take it to a repair shop?….
or did he set it on fire in burning pyre as a tribute to the roadstar gods of mischief….!!
inquiring minds and all that……
- Likes 1
Started by Gronch, 01-22-2022, 12:09 PM
by Pipevine
4 minutes ago
Started by Live2ride67, 9 hours ago
by SbTx_Rider
2 hours ago
Started by Billdozer, 5 hours ago
by SbTx_Rider
2 hours ago
Started by MarkG, 17 hours ago
by SbTx_Rider
2 hours ago
New Member
by dwilli
Started by dwilli, 2 days ago
by Engineman
3 hours ago
Started by Renegade Roger, 2 days ago
4 hours ago
Started by 07Midnight1700, 4 days ago
15 hours ago
Started by Spud116, 22 hours ago
20 hours ago
Started by 07Midnight1700, 2 days ago
Started by Blackbeard, 01-06-2019, 09:48 AM
Started by 07Roadstar, 02-28-2018, 02:46 PM
49 responses
by NthernLgts
Started by BloodMoney, 4 days ago
Started by ItBeMe, 4 days ago
Started by 08BlueRoadStar, 6 days ago
by Starman
Started by AR. Hillbilly, 4 days ago
Started by Aflion, 4 days ago
by Littlebull
Started by 07Midnight1700, 5 days ago
Started by Ronin325i, 1 week ago
by Ronin325i
4 days ago
Started by Matty1, 1 week ago
4 days ago
