Hey guys, gonna clean the carb out, Still getting pops on accel, with slight hesitation.
Seems little sluggish at times as well.
I'm suspicious that my polyurethane foam air filter, had degraded, and gotten into the intake. I flushed it out and seemed to help somewhat, but still there.
Going to break down and do an overhaul on the carb.
I decided to run thru an electrical check before doing so.
(Had a short in the stator wiring, at the harness connection last month, which I Repaired the Wires)
I then had gotten Dielectric grease all over the threads of my spark plugs and connectors in the boots. (Don't ask. It was a Noob move.. Didn't see that the grease was di electric..)
Cleaned all that off and got new plugs. Ever since these problems, I've got this popping when I try to get up on her..
Voltage at Idle holds at 14.13, but drops to 14.11 when at 2-5000ish rpms. What could be causing the resistance?
Battery is new, Charging seems good, doesn't overcharge. Just the a slight drop in volts.
Did my new stator get damaged from the short that I found in the wiring?
Would any of this cause these symptoms?
Could damage to the stator or and or, R/R be causing the misfiring too??
