I noticed slight oil leaks at the connections of the chrome oil lines on right side of the bike going from oil pump to oil tank accross the transfer case. The leaks are at no 13 and 18.
I checked the bolts and they turned loosely not able to tighten. Took the oil lines off (I have the oil drained right now as I am about to work on the clutch) and saw that the o-rings are intact but quite hard almost brittle.
And the threads in the engine case where the two M6 allen bolts go are stripped.
I assume it was leaking due to orings old, and someone kept tightening the bolts in an attempt to stop the leak but stripped the threads.
So, what is the right thing to do? I have ordered fresh oem orings and consider putting helicoils in there. What do you guys think?
