did you mention details on air box?
Not another carb post
Well I rode him to work this morning (air box back on no filter because I stepped on it ). And it started doing it again it’s a factory air boxComment
I’m going to pull my air box back off for the ride home (air filter should be there this evening) and see if it is something to do with that tho I did ride it once without a filter because the original 2005 unit that was on it when I bought it (3kmiles) was falling apart. And it behaved fine. But it wasn’t moddedComment
I'm sure the air filter isn't the issue I'm saying until you get everything in order the way it is supposed to be, that trying to diagnose an issue is worthless. You can't introduce new issues and expect to get good results. He should bring it home, take it back apart very carefully and inspect everything as it comes apart..Comment
With everything back as it should be it does the same thing. I can do a few mid range full throttle pulls and it’s fine. If I wind it up it dies off if I do too many mid range full throttle pulls it doesn’t it in the mid range unless I chill for a minute or two. It feels like it’s sucking the bowl dry. Maybe the pump is weak I don’t really know. And I took it back apart 3rd time now the stack is as barons says in the very tiny picture.Comment
So that’s the stack my instructions came with. I noticed however the intake manifold is drenched in fuel. I cut the bike off at like noon it’s 530pm1 PhotoComment
Random side note. Should the cover side of the coast enricher diaphragm be covered in fuel? Like take the cover off and the inside has fuel in it but only on the cover sideComment
ill check it again when i put it back together (waiting on pump delete parts) i keep getting varying info on what the needle stack should be this is headed down the "holly terminator custon fuel injection turbo" route if it keeps this shit up lolComment
where are you getting " varying info on what the needle stack should be" If the pic above is the stack it is correct and the same as everyone here has on there bike with a Barons jet kit. If you have a different brand jet kit it could be different depending on what brand kit you have. A Speedstar kit would be clip in the 5th groove and a dyna kit it could go in either 3rd or 4th groove depending on washer stack. Are you sure you have a Barons jet kit?Comment
Yes I bought the kit. The tps was off a little (590 ohm between yellow and black closed and 3200 at wot) the bowl looked to be wet when I took it off so I’m waiting for an oem o ring to get here.Comment
Yeah I have the grizzly needle and seat 3.0 I’ve adjusted the float height at clymer spec I’ve tried higher and lower. Sadly the stock cdi was trashComment
oh someone was asking about my old cdi. the cdi was last years drama my current one is fine. ive adjusted the float level to 5 mm above, level with the seem and below it. ive jetted it at 167.5 172.5 and 175. it does exactly the same thing every time. deleted the pump installed 3.0 seat pulled the screen etc. i dont know what jet was in it before because you cant read it but it is larger than 175. (obviously different needle and ran rich) checked by how far down it will slide on a straight pickComment
666 responses
by Txulrich
50 responses
by Mr. Miyagi
Started by Brad_G, 2 days ago
Started by Flashback, 1 week ago
Started by TorontoRoadie, 5 days ago
by Kmartcivic
Started by tapeit59, 03-18-2020, 07:51 AM
47 responses
by SbTx_Rider
by GreenMachine
Started by Roadrider, 4 weeks ago
Started by Kmartcivic, 5 days ago
by GreenMachine
1,508 responses
by Zimasfriend
Started by Kmartcivic, 6 days ago
by Kmartcivic
Started by FuryGuy, 1 week ago
by FuryGuy
by Dogbone
by Kmartcivic
