I saw in the classifieds where some of the members on here are making adapters in order to use HD wheels on their RS's, and I could use some more info. Is this for the front wheel, rear wheel, or both ? Are they replacing spoke wheels with cast wheels ? I would love to put cast wheels on my RS, I'm tired of dealing with tubes. Any info would be much appreciated....
HD wheels on a Road Star
Harley 18" wheel, rotors and tire for sale. Tire and rotors has less than 2k miles on them. I had this on my 2001 RS and is in very good shape. I pulled it off to put a 21" wheel on. Asking $150. plus the ride. IMG_2689.JPG IMG_2688.JPG Airstrike Touring Street Glide wheel. 130/70-18"
Smokescreen does a great job. I had this cast rim on my bike using his adapters, and they worked great. I removed this rim to put a 21" wheel on. I'm using those adapters on that 21" or I'd sale them with the 18" wheel.
If your needing a rim, tire, and rotors, this is a good deal.
- Likes 1
I'm playing with the idea of this swap in my mind, I'm looking to go with 16 inch rims front and rear, same as stock. From what I've read, the HD rear wheel uses a smaller diameter brake rotor so that's an issue, also the rear pulley is smaller on the HD wheel which would make the regular RS drive belt too long, so that's another issue. Plus the smaller rear pulley would make the bike higher geared, and that's not needed on RS's, they're almost too high as it is IMO. And the 180 rear tire that a lot of HD wheels use might have clearance problems, IDK, not ruling it out just yet, HD cast wheels are easy to come by and cheap enough according to people I've checked with, but RS cast wheels would sure be easier to swap in....
Originally posted by Duke View Posthttps://www.roadstarclinic.com/forum...e-front-mag-fs
I put on a 5 1/2 degree triple tree, and fiberglass fenders on. I mounted the Warrior wheel with a 200/50 17" tire on the rear. The tire being smaller in diameter, I put 33 front, 65 rear pulley on with a 128 tooth belt. So far it's been GREAT! The bike feels more nimble and lighter, and seems to be easier to go thru the turns. Between the 3 major modifications done to the bike, I'm not really sure which mods did the best, but the three together sure made a better difference with the overall handling. I will be doing some of the same mods on my other bikes, for sure.
The 108ci is a whole other story.
- Likes 2
I really liked the bike and the mods. I didn’t like the dark side tire but you would get use to that. Also, even though the wheelbase should be longer with the raked front end it felt very short, i think because the raked front end moves the handlebars back to you, i like to reach for my handlebars. And one thing that was surprising was tight turns at slow speed, aka, turning around in the road. It seam to turn on a dime but once up to highway speed the car tire seam to slow that initiation.
Ok guys to put a Harley Davidson front wheel 15 inch all I will need a smokescreen to adapters or is there more to it.
Can you speak english or take the marbles out of your keyboard?
Don't see a 15" front wheel only back ones.https://msiwheelblanks.com/pdfs/fit_wheels.pdf
Originally posted by MikeyC View PostDuke, do you remember what size spacers on the rotors for the enforcer wheels. I now have an enforcer front wheel and I have the axle spacers.LET'S RIDE
Mike, after mounting the wheel, put the calibers on with out the spacers and measure what spacer size you'll need. My caliper spacers were a little over 1/4" to center them to the rotors. You will want longer bolts (x4) for mounting the calipers.
Started by Chrominator, 4 hours ago
1 hour ago
Started by Gutterpig, 7 hours ago
by Mr. Miyagi
2 hours ago
Started by Darkkill57, 6 hours ago
3 hours ago
Started by Dave377, 5 hours ago
by Dave377
3 hours ago
59 responses
by Ciccone1234
7 hours ago
by Ahodge75
8 hours ago
Started by Brad_G, 23 hours ago
9 hours ago
Started by NCB, 5 days ago
16 hours ago
by Tykes_Place
by Kurf
Started by Mussky, 1 day ago
by Tykes_Place
by Sharpman66
