Installing Harley risers on Roadstar
  • Installing Harley risers on Roadstar
    I bought some drag specialties risers which use a 1/2-13 in bolt and I wanted to know if that will fit the roadstar tripple tree riser bushings or will I need the Barons riser bolt kit?
    https://viadon.com/portals/1/viadon/...hartviadon.pdf
      I did hear from someone that the 1/2 in bolt will work.
        Yes someone said 14mm is bigger than 1/2" Other than installing for you, my work is done here. lol.
          To directly answer your question, YES the 1/2" bolts will absolutely fit within the factory Yamaha triple tree bushings. The Factory bushing ID is .55"
          Started by 6door7r, 6 hours ago
          Started by Va. 63 Roadie, 2 weeks ago
          Last Post sprt220
          by sprt220
          Started by LDofDC, 3 days ago
          173 responses
          Last Post dbtk44
          by dbtk44
          Started by roadiemort, 11 hours ago
          Started by Roadstarkazoo, 4 days ago
          Started by Lug Nut, 14 hours ago
          Last Post Sasquatch
          Started by grubsie, 1 day ago
          Started by MRH, 3 days ago
          Last Post MRH
          by MRH
          Started by tyates007, 2 days ago
          Last Post SbTx_Rider
          Started by Airlordd1, 6 days ago
          1,055 responses
          94 responses
          Started by MikeyC, 01-11-2021, 12:44 PM
          Started by MikeyC, 6 days ago
          Started by Garvaon, 1 day ago
