Installing a external gas gauge
  • Installing a external gas gauge
    The gas gauge on the dash is shot. Has any body ever installed a external gauge using the stock sending unit in the tank. And if you have where can I get one. I am to old to walk for gas and the ex wife will not walk either.
    New sending unit is $90 and easy to install
      He is asking about an external gauge because the OEM is faulty. His sending unit works.
        Look at aftermarket fuel gauges that work between 140-143 ohms empty and 11-13 ohms full as those are the resistance numbers of the tank sender, summit racing has one that's 160 to 15 ohms that would probably work
          Are you sure it's not the sending unit? They're known for failing and I've never heard of the gauge itself going bad. Then again, you could always add a sight glass like this one.
          • Dbush72
            Dbush72 commented
            That's the general idea I'm doing to mine, to hell with the faulty factory set up...I'm gonna use the fuel gauge in the instrument cluster for my boost gauge when I finish with my turbo install!
        Started by Father Pobasturd, 17 hours ago
        Started by Michael72, 09-02-2020, 11:48 AM
        Started by Bip_Bip, 10 hours ago
        Started by Slammed&Cammed, 6 days ago
        Started by roadiemort, 22 hours ago
        Started by roadiemort, 08-22-2020, 04:09 AM
        272 responses
        Started by YZ18, 2 days ago
        Started by mariner3302, 10-22-2020, 03:16 PM
        Started by brianmac, 6 days ago
        53 responses
        Started by Shores, 5 days ago
        Started by SbTx_Rider, 5 days ago
        Last Post LeLimoMan
        Started by Lug Nut, 10-18-2020, 05:32 PM
        Last Post LeLimoMan
        Last Post LeLimoMan
