I went for a ride......
  • I went for a ride......
    I went for a ride the other day, bike started fine, rode fine for 40 minutes, stopped at a light, went to go again, bike backfired and shut off, started again on 3rd try , any thoughts?
    Musta pissed it off.
      Dirty carb/fuel... Check and clean.... Start with jets... Check fuel filter and petcock screen/filter and carb inlet screen filter. Then check for air Leaks (nipple on top of manifold etc).
        Coughing out the carb and dying, while trying to pull away from a light, isn't entirely unusual. It can happen from time to time, but if it happens often, it may be your accelerator pump needing some adjustment. Check out the article in the tech section. But before you start messing with the carb settings I'd run through a couple tanks a fuel with several ounces of SeaFoam in it. Ride it hard, working through the rev range, and be sure to do some wide open throttle standing starts, running it all the way up to the rev limiter, as you go through the gears.
          Thanks guys for the solid advice, I am not too concerned because it has only happened this one time. These bikes do seem to have their own personality, maybe i did piss it off.
            If the idle is too low it will do that...
            Started by D-Fresh, 2 hours ago
            Started by ItBeMe, 22 hours ago
            Last Post Ironman
            by Ironman
            Started by AR. Hillbilly, 20 hours ago
            Started by Lug Nut, 22 hours ago
            Started by Jokke75, 1 day ago
            Last Post sprt220
            by sprt220
            Started by Lucky, 3 days ago
            Started by DEEPHATE, 2 days ago
            Started by davej, 1 week ago
            Last Post tovarman2
            47 responses
            Last Post RRS_07RdStar
            Started by Steve, 4 days ago
            Last Post Steve
            by Steve
            213 responses
            Started by Doc_V, 3 weeks ago
            64 responses
            Started by Denis Garfield, 2 weeks ago
            Started by sycloneman, 07-09-2018, 06:49 PM
