Throttle valve
  • Throttle valve
    I have a 2001 Roadstar Silverado I replaced my intake joint and I noticed my valve throttle was burnt on right side bottom and nothing was connected to pipe coming from the carburetor Diaphragm for the valve throttle... looking to see what it Connect to..
    Oh you mean the thingmabob?
      While trying to decipher what you mean, I'd make a wild guess that you missed connecting the hose that goes to the AIS.
        nothing is connected to the fitting on the diaphragm housing
          If you're talking about the 90 degree fitting, nothing is supposed to connect with it.
            Yes the 90 degree fitting, According to the part manual it’s called a pipe thank you fellas. I’m waiting for a new valve throttle because for some reason it was burned..
              What are you calling "valve throttle".. Not familiar with that part
              Should be read as throttle valve. Punctuation is important.
              https://partstream.arinet.com/Mobile...wPxM9jSg1.html
                Thank you, I try my best to be more punctual in the future...
                  Sure your diaphragm is good if the other piece is burnt? Shine flashlight and see if any pin holes anywhere
                    Diaphragm is good but the valve throttle is burnt.. I can’t send a picture..
                      Why not just polish it?
                        • SuperG
                          SuperG commented
                          Yeah, that's nasty. Must've been fire and brimstone shooting outta that carb.
                          Oops! I thought it was metal.
                        You better tear that carb all the way down.. Whatever backfire/fire/heat melted the plastic slide might have toasted other plastic/rubber pieces! Never personally seen that before.
                          It all started when I give it just a little bit of gas in the bike with shut down and if I can’t little bit more on the throttle giving it more gas it would not shut down. Some told me to check for a vacuum leaks and I noticed my intake joint was all cracked up as I replaced the joint I noticed the valve throttle being burnt the bike backed fired a lot when I would release on the Throttle someone told me that happing because of the AIS and told me to remove it. After I replace the intake joint and took for a small ride I noticed it’s not back firing now... I believe I will remove the AIS when my new valve throttle comes in.. Thank you Fellas
                          1,009 responses
                          Started by mariner3302, 2 days ago
                          85 responses
                          Started by Lug Nut, 8 hours ago
                          Started by roadiemort, 10 hours ago
                          60 responses
                          Last Post Blackcloud12
                          Started by Doc_V, 2 days ago
                          Started by gonzarelloz, 2 days ago
                          Started by estrom, 3 days ago
                          166 responses
                          50 responses
                          245 responses
                          273 responses
                          Started by Smokescreens, 06-17-2020, 09:49 AM
                          Last Post MrG
                          by MrG
                          Started by MrG, 2 days ago
                          Started by Flyinfish, 1 week ago
                          Last Post JimH
                          by JimH
                          Started by JoeX, 6 days ago
                          Last Post JimH
                          by JimH
