2000 Roadstar carburetor HELP!
  • 2000 Roadstar carburetor HELP!
    I rebuilt my carb and after I installed it and got the fuel pump going it started dripping gas off the bottom of the carburetor. I not a mechanic by any means but I was ever so careful with it. The float seemed a little stiff before I installed it but I assumed that was normal. Is the float sticking or did I mess up the bowl gasket? I can't tell where it is coming from. I tried to make sure the drain screw was tight but I can't seem to be able to get on it while installed. I would have never tried to tackle this but nobody locally would work on it. Not even the dealer I bought it from because it's too old?? Wow dudes, good service.
    ​With enough beer you can do anything...D.Pate
    You lost the little round Oring for the accelerator pump port.
      I just closed the drain bolt from the left side of the bike yesterday using a 6 inch Allen socket and a wobble joint adapter.
      had a friend guide the Allen in for me from the carb side of the bike.
        Well I took the carb back off. The first thing I did was make sure the drain plug was tight. I must have been over zealous because the bowl cracked. It looks like my only option is a new carb as I couldn't find the bowl available separate. I found one used carb that was funky looking and over priced. Any junkyards or other options?
          ask here for anyone that swapped out their carb for an HSR 42 if the are willing to sell the old oem carb or float bowl. In fact I would send "Duke" a message to see if he might have something to help you out. He usually has things like that
            Update: The accelerator pump ring was in place. I think one corner of the gasket moved out of place. The crack around the drain screw doesn’t go through into the bowl. I removed the screw and filled the hole with silicone and replaced the screw. Now wait 24 hours and test it OFF the bike this time. Fingers crossed!
              silicone is not fuel resistant.
            Silicone will leak or clog something up. They make good sealant for airplanes that is fuel resistant. I used it on a tiny leak on my petcock worked great.
              Crap I thought for sure it was fuel resistant. Thanks guys..
                I only have a carb that is built and I'm not willing to separate those parts. Sorry.
                What I have found that works for crack repair, is JB Weld epoxy. It's best to rough up the area where your repairing. With a crack like your talking, it's best to drill a small hole at each end of the crack to keep it from spreading.
                Started by Jon D, 6 hours ago
                Started by Tykes_Place, 16 hours ago
                Last Post Jon D
                by Jon D
                Started by Blackcloud12, 1 week ago
                Started by hardone2get, 6 hours ago
                Started by Andrew, 02-25-2018, 09:53 AM
                Started by a_gunslinger, 1 week ago
                Last Post texasscott1
                Started by Squirts, 1 day ago
                Started by viper, 18 hours ago
                Started by Lyndon53, 1 day ago
                Started by J89k, 3 days ago
                314 responses
                Last Post catnaper2
                Started by Kevin Di, 3 days ago
                Last Post Kevin Di
                Started by Jaybo, 2 days ago
                Started by Overkill jones, 08-25-2018, 09:02 PM
                Started by 07 silverado, 1 week ago
                Last Post 07 silverado
                Started by Rick Fortner, 5 days ago
                Last Post Rick Fortner
