Bringing my bike back from its death bed
    Thank you sir, manual on Christmas list. I only took apart bc I was taking cosmetic covers... now I’m down the rabbit hole
    • Chromepony
      Chromepony commented
      You're most welcome.
      I got my service book in '05 off ebay for about $30. It's been worth that much at least 100 times.
      Keep us in the loop with this build-up.
    I had long shots on mine they were open and loud. I went Click image for larger version
ID:	88623 with the Cobra power pro 2 into 1 and had a noticeable increase in HP and TQ. MIght not look as good on a bobber though.
    • Chromepony
      That's a real nice scooter you got there, Bubba.
    What size hex head is under the forks? I gotta borrow a longer socketed one from work and forgot to check before leaving...
      Tried a ratchet.. alien bolts on bottom of forks don’t budge.. then tried 1/4 inch impact.. still nothing.. try half inch impact?
      • Chromepony
        3/8" impact should make it come; 1/2" will for sure
      Brought the forks to work. My mechanics are smarter than me. He put a screw driver in one hole and ratchets on the bolt and it came out. Got them fully apart now. Going to order the bushings and crush washers now, there is some wear on the brass... now the real question is do I order new springs too?
        Yup! While you're in there, might as well inprove the suspension. My preference is Race Techs.
      I would do the Gold Valve emulators as well as the Race Tech springs. The springs made a massive difference but I seriously kick myself for not doing the emulators at the same time. I have a new front wheel coming and am thinking about dropping the forks and doing the emulators too.
      • #27
        Yes for the price Race Tech Springs. Love mine too. Also I DID NOT use the Emulators.
        • #28
          That's right...you're already in there.Do the emulators now & enjoy the ride !!
          • #29
            Went and talked to the local bike shop and ordered bushings and springs through them. Went with 95 spring rate in case I ever go two up again.. he talked me out of the emulators. I think this will be enough for me. And maybe do the road wing at a later date
            • #30
              Also 10w oil or 15w now with race techs?
              • #31
                So how do you change the lower slide bushing? It looks like it’s recessed into the inner fork
                • Chromepony
                  Find where the bushing "meets itself". With a small flathead screwdriver or pick,carefully lift one side of the bushing & remove it from the slider.
                  Install the new one in the reverse manner...much like installing new piston rings.
              • #32
                130 mm of fork oil and 25 mm preload sound like correct figures from racetech website, just didn’t know if anyone played with any other numbers
                • #33
                  It’s starting to get cold out in the shed...
                Started by Parhamj, 4 hours ago
                Started by Pauli466, 3 hours ago
                Started by Kenkaman, 11 hours ago
                Started by Ret HPD, 20 hours ago
                Started by gold03, 1 week ago
                Last Post gold03
                by gold03
                Started by Lucky, 4 days ago
                Started by Father Pobasturd, 11 hours ago
                Last Post Spydr
                by Spydr
                Started by ItBeMe, 6 days ago
                Started by jjvw, 1 week ago
                Last Post jjvw
                by jjvw
                Started by GNR10, 1 day ago
                Last Post Gizmoinok
                Started by cap-tech, 3 weeks ago
                Last Post Vicious
                by Vicious
                Started by GNR10, 1 week ago
                Started by Jaybo, 3 days ago
                Started by oldbw, 1 week ago
                Last Post oldbw
                by oldbw
                Started by cike, 1 week ago
                Started by Ret HPD, 2 weeks ago
                Last Post Ret HPD
                by Ret HPD
                Started by area1509, 3 weeks ago
