Roadstar ground cable
  • Roadstar ground cable
    Question, where does the battery ground cable connect to the frame? Thanks.
    Stock, is connected to the allen bolt that holds the dip-stick tube on the oil tank. I think the stock ground is a little cheesy.
    I have the heavy cables for the starter and ground, and made the ground cable longer to go to one of the bolts that hold the transfer case to the engine.
    Click image for larger version  Name:	IMG_2067.JPG Views:	2 Size:	106.3 KB ID:	64432
    • Lucky
      Lucky commented
      Duke
      Thank you very much for the quick reply! And the photo.
      I think on my custom build I will connect to the area that you did. Thank you.
    The other small wire that comes off the ground cable is the ground for all the other low amperage accessories on the bike. When I connected the new ground cable to the oil tank the voltage drop from the battery to the starter casing with the starter engaged was 0.06 volts so the oil tank is sufficient. Just make sure the tank bolt is clean. So far as I've been able to determine there aren't any ground wires connected to the frame.
    Scott B.
    • Lucky
      Lucky commented
      Thanks Texas Scott1
Started by Father Pobasturd, 11 hours ago
Started by Texas Jim, 1 day ago
Started by KCpartsguy, 1 week ago
Last Post jeckert
by jeckert
498 responses
Started by Anthony385, 5 hours ago
Started by Zimasfriend, 2 days ago
68 responses
Last Post fastjohnny
Started by midnitmike, 2 days ago
Last Post LeLimoMan
Started by cike, 1 day ago
Last Post LeLimoMan
Started by Roadman68, 2 days ago
Last Post LeLimoMan
Started by 6175biker, 18 hours ago
Started by Kenkaman, 21 hours ago
Started by Scjpll, 19 hours ago
Started by ItBeMe, 23 hours ago
Started by boomerA, 1 day ago
Started by Jclevesque, 18 hours ago
Started by Smar84, 04-30-2019, 08:44 AM
Started by Mitch82, 3 days ago
Last Post Mitch82
by Mitch82
Started by Knutselsmurf, 03-31-2019, 03:17 PM
Last Post Knutselsmurf
Started by Tykes_Place, 02-15-2018, 11:30 PM
232 responses
Last Post p birk
by p birk
