Lucky, is there a part number for the Dynatek 3000 i'm looking for an ignition system for mine and don't want to use any of the stock stuff.
Lucky's Black Diamond Build
Rad! So to clarify on the geometry, is the frame 3up 2out? And the springer is 1under? Are you going to put the battery under the oil bag?Just a dude, playing a dude, disguised as another dude.
Today April 22,2019
I might get the machined adapter back from the machine shop to install my front wheel with brake.
The adapter was to give clearance between the brake caliper and the spokes.
The wheel will also be centered in the forks. 11.5" brake disc on a 77-83 Sportster front wheel.
I will also have room for the Harley speedometer drive that is 2240:60 ratio on a 21" front wheel.
Avon Roadrider 90/90 front tire. Ultima 4 piston brake caliper. Stainless Russel brake hose.
OK....Moving forward again. April 23,2019
Today I got the special spacer that was machined by Metal works Precision Machine& Tool in Tucson.
They were on the Eastside of Tucson instead of along the Freeway like most metal businesses.
Good for me so I do not have to drive 23 miles to get help.
So I was able to assemble the front wheel so that the caliper does not rub on the spokes, and the wheel
is centered in the front forks. Very important.
So it is a 77-83 Sportster front wheel made for 2 10" front discs.
It was advertised and sold as a 1984-99 Sportster wheel.
I have a 11.5 Inch disc mounted on a special spacer on the L/H side
that mounts on a 2.4 inch hub mount and the spacer accepts a 2" or 2-1/4" disc mount hole. A standard HD style brake disc can be replaced .
It is a DNA Caliper mount with a Ultima 4 piston brake caliper.
Hey Lucky,
I like the looks of your seat was it custom made or did you to buy it. How wide is it and how long is it? Does it feel comfortable?
Just curious, are you able to leave the transfer case on in that frame if you wanted to?Just a dude, playing a dude, disguised as another dude.
It might be possible but I have not measured it.
I built a previous bike just like this one that did incorporate the
transfer case. Just useless weight designed to lower the belt drive speed.
Since both bikes were chain drive there was no need for the transfer case.
Using the transfer case does save money because you do not have to buy an oil tank.
Almost ready to start the bike up. all I need is the air filter bracket and bolts that hold it on. It was missing when I got the engine.
I just noticed it was missing. I hope to get it in the mail today. I do not think it it will run right without the filter.
I will go get my gas can filled today. Maybe I can start it up tomorrow.
by Sasquatch
1 hour ago
Started by Lug Nut, 7 hours ago
1 hour ago
87 responses
7 hours ago
Started by TorontoRoadie, 2 weeks ago
7 hours ago
Started by roadiemort, 11 hours ago
by Jclevesque
10 hours ago
Won’t start
by MRH
Started by MRH, 17 hours ago
11 hours ago
1,054 responses
17 hours ago
18 hours ago
Started by Airlordd1, 3 days ago
18 hours ago
Started by JC32, 3 days ago
by EP Roadie
21 hours ago
Started by Tykes_Place, 2 days ago
by EP Roadie
21 hours ago
Started by Roadstarkazoo, 1 day ago
by RRS_07RdStar
21 hours ago
170 responses
Started by MikeyC, 3 days ago
Started by rdpickard, 1 week ago
by rdpickard
by Bikerron
Started by DEEPHATE, 2 days ago
by Bikerron
Started by Spokes729, 2 days ago
