Engine going in today
  • Engine going in today
    Here we go !
    It’s in there !
    • Questcap
      Questcap commented
      It's a beautiful thing!
    Got a new part to fix this jack leg repair
    • Questcap
      Questcap commented
      That's ugly! Just the front air filter mount, isn't it?
    • Rob in FL
      Rob in FL commented
      Yes, it's even worse in person looked like they jb welded a nut to the head. I found a nice one on eBay for 8 dollars!
    They had a chrome look powder but unfortunately there was some issue with the parts off gassing? I’m not familiar with how the system works but the black looked better it was hazy in spots with the chrome look. I dropped the rocker box covers off they are pitted pretty bad on top and the chrome is coming off in chunks so hoping for the best on them
      I stopped by my local Yamaha dealer to get some o rings, not sure if I'm calling the part by its correct name but the adapter that the oil filter attaches to, it has 4 bolts there are 2 o rings on the back. $ 8.56 for the 2 o rings! That makes HD parts seem cheap !
      • Lucky
        Lucky commented
        Never go to the dealer for parts!! No No No
      • Lucky
        Lucky commented
        You can get O rings at True value hardware store. No need to pay Yamaha and all of the middlemen. I just bought a 1/4" diameter O ring for the carb float bowl for $.25 this morning from ACE hardware.
      • brianmac
        brianmac commented
        you cant get of of an HD dealer for under 50$
        i wouldnt muck with any non OEM oil orings, chinese man say, YA , DAY made of OYAL RASISTAN NEO PREEN SHUWA OF A COSS. hahahahahaha
        get ur stuff from partzilla , less stealer markup, and in stock.
      Here’s some pictures of the rocker box covers I’m not even sure if he can save them
      • Questcap
        Questcap commented
        Anything can be done... for the right price. What you're seeing is that much that Yamaha made was from some pretty poor cast metal and plating. A blast, some smoothing, or whatever, and whatever finish you want to go for will make them look show quality. OR, you could shop for a set in like new appearance, and start out ahead of the game.
      • Rob in FL
        Rob in FL commented
        Got them powder coated gloss black they look amazing now
      • Lucky
        Lucky commented
        Florida is where the American Welding Society does corrosion testing.
      Lookin good man! What's the story on this bike? Do you have the complete bike or are you parting it together? What's end goal?
      Just a dude, playing a dude, disguised as another dude.
        Parting it together. I retired in February so I needed something to do unfortunately I have lingering back issues from a failed surgery so I can only sit or stand for about 30 minutes then I have to go lay down, it’s moving along and I should have all the rear suspension in by the end of the weekend. I hope you get that starting issue worked out. I hear a lot of people say to use the warrior starter and a lot say to use bigger cables I got the larger battery cables hopefully It will Work.
          Have you tried inversion therapy?
        • Rob in FL
          Rob in FL commented
          I have been doing decompression treatments 3x a week I did try inversion but it hurt too bad with all the nerve damage
        Sorry to hear about your back issues. I've had a back injury before, so I have had a taste of how debilitating that can be.
        That's a sweet project though. I fun project that you will eventually get to play with.
        Yeah, if I can't figure something else out, the cables and a Warrior starter will be my next moves. Thanks.
          Got a big box today! It's the transfer case got it from fallen cycle in Daytona beach, Fl. I was expecting it to be really heavy feels like 40-50 lbs. I'll cut the box open in a bit and take a look,it's too damn hot and humid in the garage right now.
            One mounting bracket a little bent but that’s an easy fix just need to scuff up the parts and mix up some flat black to spray. It’s moving along !
              Cleaning up and polishing the chrome parts I’m going to keep. I didn’t get the transfer case o rings and gaskets in yet. Going to paint the transfer case this weekend so it will be ready when the gaskets arrive
                Picked up the rocker box covers today. The powder coater did a great job fixing them (as rough as they were) polished up the used cobra 2-1 exhaust I bought for 200. I will get the rocker boxes mounted and get some new photos I'm going to try to get the back wheel together this weekend and get it mounted
                • dustybin
                  dustybin commented
                  they came up a treet , did they cost a lot over there to get coated
                • Rob in FL
                  Rob in FL commented
                  75 each they blasted the inside and outside lots of hand sanding and then the powder I'm really happy with their work
                • Rob in FL
                  Rob in FL commented
                  The rocker boxes came out nice for how rough they were. Polished up the used cobra exhaust also
                • Kevstephenson7
                  Kevstephenson7 commented
                  mmmmm!
                You're well on your way! Are you in need of anything, or do you pretty much have it all?
                • Rob in FL
                  Rob in FL commented
                  Just need a speedometer
                • Questcap
                  Questcap commented
                  Haven't one of those to spare, sorry.
                Took me 2 days and a gallon of aircraft stripper but I didn't let it beat me. Now I can start the body work
                  There's got to be an easier way...
                  • Lucky
                    Lucky commented
                    Use epoxy stripper, NOT paint and varnish remover.
                  My compressor isn't big enough to run air tools for long or I would have gone after it with some 36 grit, just glad it's done that aircraft stripper stinks !
                    Got the dents pulled as best I could and got the first coat of filler down and blocked. It's coming along
                      Making more progress
                        What wheel and tire size are you running back there Rob? Looks good.
                      • daveto
                        daveto commented
                        Not sure if it’s because it’s black but that pulley looks gigantic
                      • Lucky
                        Lucky commented
                        Great job you are doing!
                    Started by coolalexrex, 2 days ago
                    Started by Hank1988, 01-21-2021, 09:23 AM
                    Last Post Va. 63 Roadie
                    186 responses
                    Started by Jclevesque, 5 hours ago
                    Newb by bbf
                    Started by bbf, 3 days ago
                    Started by HMWREKR, 1 week ago
                    Last Post hoytcanon
                    Started by Sasquatch, 1 week ago
                    Last Post Sasquatch
                    Started by TexFer, 3 days ago
                    Last Post bbf
                    by bbf
                    Started by Dwizzle6123, 1 day ago
                    Last Post bbf
                    by bbf
                    Started by Sharpman66, 21 hours ago
                    Started by Robmrtrct, 1 day ago
                    Last Post BrokenWheel
                    Last Post BubbaKahuna
                    Started by TorontoRoadie, 1 week ago
                    Started by Wolfman, 2 days ago
                    112 responses
                    Started by Shores, 6 days ago
                    Started by mariner3302, 10-22-2020, 02:16 PM
