Oil coolers on the triple tree
  • Oil coolers on the triple tree
    Hello fellas,
    i have some bloody idea in my head...
    I would like to install oil collers on the triple tree...
    Between the coolers and adapter i like to install automatic jag 4050 bypass valve... The question is the oil pressure gonna be enough to reach the top ?
    Whats is your opinion?
    Honestly....dumbest idea I've seen for a Road Star. Ever. So overcomplicated and unnecessary and weird looking and more potential areas for problems to arise. Just absolutely unnecessary.
    Has your motorcycle ever overheated and shut itself down? Do you use full synthetic Vtwin oil? What made you think that your bike needs all this extra cooling? These bikes have been around since 1999 and have been ridden in the desert in 100 deg heat all the time without issue. Only way these bikes are gonna overheat when the idle is where it should be at and in a good state of tune...would be if idling for long periods of time in the heat, which is never a good idea.
    If you feel the need for liquid cooling you would honestly be better off with a Royal Star V4....great bikes ..hyd clutch...tons of hp...smooth...radiator....
    • Renegade
      Renegade commented
      Last summer in the jam happened on the crosslight,but he start directly withiut problem. I decid eto hook up the cooler on the triple tree without to connect the hoses ...
    I know the fuel injected Roadstars will shut down when they get too hot. DK about the carbonated ones. If you're going for just looks, just bolt those coolers on and forget about the oil lines.
    • Renegade
      Renegade commented
      I will do that
    I have had a check engine light come on trying to get through traffic in DFW. Just stop somewhere and let it cool down for around 1/2 hour and then back on the road. I am on a FI bike.
      • Mr. Miyagi
        Mr. Miyagi commented
        My check engine check light must be out.
      if you have a over heat issue while riding in traffic get a parade fan. A cooler only really works when air is passing over the fins and that ain't happening while riding slow in traffic.
        Yamaha tried putting engine cooling up on the forks of dirt bikes in the early 80s.
        It was abandoned immediately.
        Forks move in relation to the frame/engine ... a lot.
        Far more than normal coolant & oil lines are designed to move unless you use brake lines or something designed specifically for high temperature hydraulics.
        You'll also probably need to modify them or have them custom made.
        The constant flexing will likely leak sooner than later & when it does, you will 'oil down' somewhere on the road.
        You can almost guarantee it won't be close to home.
          Thanks guys for the tips. Thisis my next project 300 35 18
              Are you using a swingarm kit or are you going to build a wider swing arm?
                New Swingarm?
                Chain Drive conversion?
                Magic Wand & a Big F$$$ing Hammer? LOL
                  I have already rear 240... 6 months ago i bought 300 swingarm,and the last week rear rim 10x18. Rear rim come with adapter for stock 300mm brake rotor. I need to save little bit more than i will order to friend of mine new custom steel rear fender for 300 tire and custom sissybar... I will post some pictures in the next few days.
                    Originally posted by rrps18admnrsc View Post
                    New Swingarm?
                    No chaindrive i will keep the pulley. For the 240 i use Harley tiny belt, for 300 i have use same one or i can put the stock belt.
                      I like the look of the 300 on a Road Star, not real practical but badass!
                        Originally posted by Lug Nut View Post
                        Unlike the look of the 300 on a Road Star, not real practical but badass!
                        Yes, you are right... handling is difficult, look is mortal combat...its all about look... i start working on new electric.
                          I see you have a 1999. The only time i had an issue with heat involved fuel vapor lock due to the fuel pump and the way that whole system was set up to the carb. Once I got rid of the pump I never had another problem with riding in hot weather and I live in NM.
                            I removed the fuel pump,plus i replace the stock carb with hsr42...im pretty happy with the bike and set up i have...
                            Last Post Kurf
                            by Kurf
                            Started by Aflion, 1 hour ago
                            Started by AR. Hillbilly, 6 hours ago
                            Started by 07Midnight1700, 20 hours ago
                            Last Post 07Midnight1700
                            Started by Ronin325i, 1 week ago
                            Last Post Ronin325i
                            Started by Matty1, 2 days ago
                            Started by Lug Nut, 4 weeks ago
                            Started by Debevec, 2 days ago
                            Started by Tomtom123, 2 days ago
                            Started by Mc765, 1 day ago
                            Last Post Gwhiz
                            by Gwhiz
                            Started by Jammin'John, 2 days ago
                            Started by 08BlueRoadStar, 2 days ago
                            Last Post Debevec
                            by Debevec
                            Started by 08BlueRoadStar, 4 days ago
                            Last Post Matty1
                            by Matty1
                            Started by MikeyC, 4 days ago
                            1,450 responses
