Bnag0 - The Killers Resurrection
  • #61
    Option 2 will definitely take me a lot of extra time as each image will have to be entered individually. Unless there is an easier way to add a group of images? Option 1 is just as fast but kind of stinks not to see the image.
    • #62
      Waiting on some more hardware/bungs for the seat and fender install so I decided to make a new intake "housing" as the one I had was pretty half ass thrown together a few years back. Didn't get her complete but I think you guys can see what im going for in the last picture.
      • #63
        • #64
          I'm really enjoying seeing all your fab work. Thanks for sharing.
          • #65
            Did you have trouble getting the SS bolts into the bungs you welded in? Did they get stuck on the way out? I'm curious of the failure type. I'm not a big fan of SS hardware for that reason, most of it is pretty soft and breaks easily (IME).
            • #66
              I usually try to test with steel first. If that doesn't go well I chase the threads and depending on how lucky ive been also use neversieze lol
              • #67
                Thanks Brad,
                Its been pretty fun so far. Learning a lot and wanting a tig welder more and more lol.
                  Yeah a tig would be cool. Saw a guy use one many years ago. He was showing off his new welder and what he could do with it. Looked a bit slower than mig but the results were beautiful.
              • #68
                I wasn't going to say anything but since you brought it up... I love TIG and it would be especially well suited to what you are doing, you're working way too hard! LOL
                • #69
                  I know man! I am pretty new to sticking metal together but I've worked as a processing engineer at a metal fabrication shop for the past 12 years so I do have some experience in fabrication. My wife bought me this Hobart 140 a few years back to get me started and I'm glad she did. I would rather leave some decent looking tig welds on my parts and not touch the grinder! That is when and if my tig welds ever look presentable lol.
                  • #70
                    More progress with intake and seat pan.
                    • #71
                      Added some rear gussets to the seat pan. Will be drilling (4) holes and welding in bolts that will pass through to the bottom. The (2) in the rear will pass through some brackets I weld onto the frame. The front (2) will bolt to a piece of flat bar that will then bolt to the frame. The idea is to give my seat a little bit of adjustment front to rear. Hoping I can start speeding up the process so I can ride this damn thing this season.
                      • #72
                        Got the rear seat brackets and seat studs in tonight. Going to cut the front bracket/tab from stainless at work this week. Almost ready get the foam stuck!
                        • #73
                          A mazing…. Loving this build and the thoughtful fabrication work
                          • #74
                            Thanks Kev, Hopefully get a chance to throw some foam on the seat this week.
                            To-Do List
                            1. Get front seat bracket made
                            2. Make and weld in front seat bracket bung to frame
                            3. Drill seat pan perimeter for rivet holes
                            4. Attach foam to seat
                            5. Sub out seat cover work?
                            6. Finish Intake Mount.
                            7. Make upper and lower fender brackets.
                            8. Weld threaded bungs to fender
                            9. Make Sissy bar
                            10. Mount and wire rear signals and tail light (To sissy bar?)
                            11. Modify exhaust tips
                            12 Finish welding foot controls in place
                            13. Find some poor soul to inspect this pile.
                            14. Go ride, inspected or not.
                            • #75
                              Got the front seat bracket bung tapped. Decided to paly around with the yoga mat foam and the high density foam from Joanne Fabrics. The Yoga mat is roughly .50" thick but a little too firm. The green HD foam is too soft and at 2" thick its hard to work with. I think my plan is to go 3 layers of yoga mat and then try out some gel seat pad material i just ordered from Amazon...
                              https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                              • #76
                                Got the exhaust modified with some turn out tips.
                                Starting to plan out the fender mount locations
                                • #77
                                  One of three fender connections complete
                                  • #78
                                    Sorry for the lag in updates, I threw my back out moving the kids bean bag in the living room lol.
                                    Been taking it easy but I have a little progress on the seat. This is officially the first part on the bike that I have painted lol.
                                    • #79
                                      Now to figure out a wrap
                                      • #80
                                        Cool. I never thought of using lemon Jell-O as a seat cushion.
                                        Started by Lug Nut, 6 hours ago
                                        Started by joej85a, 1 day ago
                                        Started by bigjames, 2 days ago
                                        Started by ItBeMe, 10 hours ago
                                        Started by DWD6955, 4 days ago
                                        Last Post DWD6955
                                        by DWD6955
                                        1,315 responses
                                        Started by Snotrub, 2 weeks ago
                                        Last Post DWD6955
                                        by DWD6955
                                        Started by [email protected], 1 day ago
                                        Started by Jwojtt, 1 day ago
                                        Started by MikeyC, 07-11-2022, 11:19 PM
                                        Started by Hairless Hippy, 1 week ago
                                        Started by brianmac, 3 weeks ago
                                        Started by Roadstar_Rob, 5 days ago
                                        Last Post 6door7r
                                        Started by Der Steppenwolf, 4 days ago
                                        Started by ebaleytherogue, 04-22-2019, 11:08 AM
                                        Last Post JJansen
                                        by JJansen
                                        Started by CHEAPOMCGEE97, 2 days ago
