Update/dewinterize RS
After 60+k miles together, it’s time to go through the entire bike, change ALL fluids, (normally done every 3-4K miles), filters, bearings, brake resevoir O-rings, rebuild carb, etc. Will be changing rear wheel to match the front, updating the Tricky-air-ride suspension and backing up with an airbag and air tank, designing & installing flame throwers, upswept fish tails, removing saddlebags and luggage rack (I will be keeping for long trips), changing coils to Dyna’s, triple trees with 6 degree rake and changing out fuel tank to old set of Harley split tanks, I am even getting a real upholstered seat….here are pics of how she currently looks. In the past I have looked here for advice from a past blog, if I get stuck, I’ll ask for advice.
Starts03-12-2022Ends03-13-2022Tags: None
Removed luggage trunk & saddlebags. Included here are photos of saddlebags mounting brackets and how they are bolted together with under fender cross brace. They are mounted on the same lower bolt as the saddlebags crash guards (came off a Harley, but I had to cut & add 2-1/4” of steel rod for the upper mount to reach bolt behind seat.
Dechromed the spokes with a green scratch pad and hours of elbow grease. My metric axle would not fit my new standard wheel/bearings so I took the axle to a machine shop where it was put on a lathe and trimmed to fit saving myself $$ having to press out new/old bearings and press in new bearings…replaced drive belt & detailed the area.
Started by Sykobox, 2 hours ago
by Mr. Miyagi
25 minutes ago
Started by KFallsRider, 4 hours ago
by Mr. Miyagi
27 minutes ago
Started by 6door7r, 7 hours ago
29 minutes ago
2 hours ago
Started by roadiemort, 3 hours ago
3 hours ago
Started by Mad Maj, 4 hours ago
by Tcontrol
3 hours ago
Started by Kmartcivic, 13 hours ago
by Engineman
3 hours ago
Started by Mad Maj, 2 weeks ago
by Mad Maj
4 hours ago
Started by brianmac, 16 hours ago
by Shotround
10 hours ago
103 responses
by Bnag0
Started by 6door7r, 4 days ago
by Chromepony
Started by Tykes_Place, 3 weeks ago
Started by p birk, 5 days ago
by Tcontrol
57 responses
by Shotround
Started by luff_tackle, 2 days ago
Started by jb3472, 3 days ago
Started by ABCarr, 5 days ago
by ABCarr
Started by BloodMoney, 04-15-2022, 02:28 PM
by BloodMoney
