My first bike build - Roadstar 1600 Cholo / Vicla project
  • #41
    Bump...
    • #42
      I give up
      There are to much small ”damage” because of my crappy welding machine i had, and cause im not being a welding pro either
      Been tryin to weld, grind and so on for to many times now, the material is going to thin.
      wont be worth the money to chrome it..
      i might build a new one and use the old school gas weld, and get that chromed.
      but will ride for this to begin with..
      what to do..? Paint it black? If i leave it as it is it will rust lile
      first time on the road
      • #43
        We’re goin’ loow!
        • Solo
          Solo commented
          Can’t wait to see your sled finished!!
        • Dr. D
          Dr. D commented
          Nice touch with the happy/sad faces in the mirrors.
      • #44
        Solo, fun to hear!
        Dr. D, well i'm sad to tell you, that's not my work of art haha
        • #45
          At least i got some sh*t done this weekend. Painted the rear end..
          and started to rebuild the rear as well..
          looks good so far, but will be more chrome added to
          And yeah, i made some floorboard inserts to!
          Just didn’t want to have same as everybody else, so i made them out of leather
          • #46
            Did a quick wash today, added some chrome at the rear end, and she got to se the sunlight for first time for a very long time..
            Rear lights, some electrical stuff, bleeding the rear brake, making exhaust brackets and some painting left to do.
            probably something i forgot tho
            • Solo
              Solo commented
              The fender looks good! What are you using for exhaust brackets?
            • ElVispo
              ElVispo commented
              Thanks Solo!
              I think it will be 6*30mm flat iron (don't know if you call it that in english, direct translation from Swedish haha).
              I have made attachments in the frame to attach them, now I will just figure out the shape of the brackets themselves .. and get them fixed in the pipes in some way.
          • #47
ID:	138237 Click image for larger version
ID:	138236 Click image for larger version
ID:	138235 Here are pictures of the dual exhaust brackets, hope they help with ideas for your duals…
            • #48
              Hey if you want to add to the chromed rear end since you got the phantom axle covers you can buy a couple of sets of Harley Davidson down tube covers which are the same size as the tubes on the swing arm to make some easy chrome covers for the rest of the swing arm.
              https://www.revzilla.com/motorcycle/...?sku_id=950645
              Just cut them to length and then make sure to seal over the cut area to prevent future corrosion. I used those for the frame areas under the seat to complete the chrome out of the frame. They will work on the down tubes on our bikes as well and the tubes on the swing arms of our bikes.
              Go ahead, I dare ya.
              • ElVispo
                ElVispo commented
                Oh thanks for the advice!
                Thats really a good idea!
              • ElVispo
                ElVispo commented
                Lifegurad, a little OT but.. I LOVE YOUR rear belt pulley, where is it from, or did you make it yourself? :O
              • Lifeguard
                Lifeguard commented
                The rear belt pulley was a type that was sold a long time ago and made poorly. They cut the teeth in the pulley with really sharp edges that cut the crap out of yiur belt. I still have it but will have to grind down each sharp edge before i use it again. Also to teeth are just slightly too far apart and so I believe it may be responsible for the belt ribs being torn loose. I don't use it now since I replaced the belt. I may get back to it if I grind the edges on all of the teeth of the pulley and try again.
            • #49
              Thanks fot that, might be helpfull!
              • #50
                My jack dosn’t lift 100% straight, my floor aint straight and the stand is (like you know) a side stand.
                HOW will i get the tail light and the turn signal bracket straight? Lol
                Was thinking about laser, but that requires that the bike is totally lined up straight Click image for larger version
                  Set it on wooden blocks across the frame rails. Then buy a 5 dollar torpedo level and shim it to perfection.https://www.amazon.com/Kapro-229-32-...174394&sr=8-38
                • ElVispo
                  ElVispo commented
                  Roadiemort, yeah but then the blocks needs to be 100% perfect and as i said my floor aint even straight..
                  but lets say i go for that, how the f… would i het it up there? My jack goes all the way under the frame rails haha
                  If you can't figure it out then go back to bed lol.
              • #51
                Hey man, at least you've got a heated shop. It ain't fun wrenching in the cold up here in MT.
                And you aren't constantly moving your woman's' shit that she just tosses all over the place. Nothing worse.
                • #52
                  Hey!
                  i don’t know where you get that from, but no, i have absolutley no heat, and no isolation.
                  its been cold as ice the whole winter since i live in Sweden.. and i have so large gap between the garage doors så when it’s snowy outside, it kinda gets snowish inside as well
                  • Dr. D
                    Dr. D commented
                    You and I have much in common then. It sure sucks, but it builds character wrenching in a cold ass shed.
                • #53
                  Nice Job! Looks great!
                  "Don't ride faster than your angel can fly"
                  • ElVispo
                    ElVispo commented
                    Thank you sir
                • #54
                  I f*cked up, big time lol. Used the wrong white paint so i took a very much to yellow-ish on the rear fender… AND i removed the masking tape to soon, that did do some damage as well.. and i painted when it was waat to cold! But i was in a hurry and didn’t think things thru..
                  I dont have time to re do it now, this will do for the season, and maybe i will paint the entire bike after summer..
                  I mean, im faaar from perfect, why should not my bike match up with me?
                  • Dr. D
                    Dr. D commented
                    Life is a dance, you learn as you go. Still rather impressive work - certainly better than anything I could do. I recently had a fuck up wrenching in the cold - I know that plastic wire connectors don't like to be handled in 15*F, yet I was in a hurry and wasn't thinking logically. Like you, I regretted that decision.
                    I agree with the machine representing the rider - that's why all my rigs are ass ugly, but run like new and always ask for more.
                    For what it's worth, I like the look of that eggnog-ish white. Looks much more retro and unique.
                • #55
                  Thanks Dr D!
                  yeah i know it gives more character, and well.. it will never be perfect when i do it myself.. and not with all shit around like painting when it’s cold and so on haha..
                  and YES i like the of-white more! But it sucks that it aint the same on the tank and front fender haha..
                  well, here’s a picture from like one hour ago when i got the fender back on the bike Click image for larger version
                  • Solo
                    Solo commented
                    Looking good!
                • #56
ID:	139272 Click image for larger version
ID:	139271 Well, we’re gettin’ there! Not done, but it feels close now
                  • #57
                    First short test ride
                    It seems to ride pretty well, even tho i have to bleed the rear brake, but i couldn’t wait to try it
                    The exhaust needs som more paint to, but runned out of paint. Missing some chrome, but at least im staring to feel the light at the end of the tunnel lol.
                    Click image for larger version  Name:	DD8C31DB-3318-48A5-A2E5-1804C574A7E6.jpg Views:	1 Size:	882.5 KB ID:	139543
                    • #58
                      Well yeah, i really hate to admit it, but i might have gone a tiny bit to low tho..
                      Got stuck where i usually turn around to get back in the garage.. damn it
                      • #59
                        A 140/90/16 tire and adjustable dog bones will help with that.https://www.tacomaworld.com/tirecalc...0r16-140-90r16
                        • #60
                          Just relocated the signal horn, a bit lower and centered.
                          It might be a tiiiny overkill to make the bracket out of 6mm iron.. but i think it looks good, and thats what i had at home from building exhaust brackets
                          Started by p birk, 3 days ago
                          57 responses
                          102 responses
                          Last Post Bnag0
                          by Bnag0
                          Started by luff_tackle, 1 day ago
                          Started by roadiemort, 12 hours ago
                          Started by Tykes_Place, 3 weeks ago
                          Started by jb3472, 1 day ago
                          Started by ABCarr, 3 days ago
                          Last Post ABCarr
                          by ABCarr
                          Started by BloodMoney, 04-15-2022, 02:28 PM
                          Last Post BloodMoney
                          Started by Tykes_Place, 2 days ago
                          Started by BloodMoney, 1 week ago
                          Started by Sabotage, 6 days ago
                          Last Post Sabotage
                          Started by LordOfTheBuzzards, 3 weeks ago
                          Last Post LordOfTheBuzzards
                          Started by ItBeMe, 3 days ago
                          Started by 6door7r, 3 days ago
                          Started by Shores, 5 days ago
                          Started by CoolCheech, 6 days ago
                          Last Post 6door7r
                          Started by Standish3, 3 days ago
                          Last Post Standish3
