Roadstar Exhaust
  • Roadstar Exhaust
    Hello everyone new at the
    forum. I have a 2002 roadstar 1600 i am taking off the after market exhaust and installing the original. Can i leave the carb and air filter alone or i need to rejet to original specs. Right now i have stage 2 jets and hypercharger air intake. Thank you in advance for your wisdom.
    What air filter do you have now? Stock box or open filter?
    What pipes are you removing, and why are you going back with the stock
    pipes?
    • George
      George commented
      Its a K and N hypercharger the reason i am going back to original exhaust is that i am shipping the bike over seas. Amd its just to loud.I am removing sampson straight shots.
      Thank you.
    from Athens, Georgia.
    I would leave the carb alone initially & see if the motor is happy (or not). I prefer a motor running a little fat. It will run cooler & pull better on the Big End.
    If you have a problem fouling spark plugs, step the jetting down a baby step.
    Enjoy the ride !
    • George
      George commented
      Thank you for the response i will try it. Cheers
    remember the HC used to have a different air vent to the top of vacuum slide also. if u smoke, makes a dandy ashtray.
      I 2nd the "why are you going back with the stock?"
      • George
        George commented
        I am shipping the bike over seas and its just to loud .
      Where are you located?
      Pic of current exhaust?
      You will not be certain if jetting unless you physically remove and inspect them. Also, they Hypercharger (complete piece of shit useless air filter system BTW) calls for the air bleed jet to be changed out also SO if you remove the hypercharger you need to check the air bleed acrew/jet and verify if it's a 1mm or 2mm.
      • George
        George commented
        What other air filter intake would you suggest. Thank you
      Thank you for all responses what will be a better intake system than the hypercharger
        I run a Baron's Big Air Kit on my fuelie. Don't know how it compares to other fully exposed filter setups, but this is the direction you want to go. Or AT LEAST open up the stock air box if that's the look you want. there's a write up on the site from someone who drilled one out and found success with it. If I hadn't have come across the BAK on ebay as someone's old stock, this is the route I was going to go just to get some airflow into the motor
          annnndddd ... I'm with Lug. what's your current exhaust? I've done the stage 3 on the stock, and I'm happy with it, it does sound really good without being overbearing.. but I might be looking to pick one up if the price is right
          • jgreenfi
            jgreenfi commented
            I second on the stage 3 with the stock exhaust. Not obnoxious at all and a VERY nice "crack" when you want it. Nice tone and at highway speeds gives a great little rumble. I almost don't want to use the radio in my fairing as I'm lovin' the sound now of the big v-twin.
          Going overseas with it... If it aint broke, don't puck with it.
          Scotto
            from Ontario, Canada.
            "It's not the destination...it's the ride"
              from EL Paso, TX
              Started by Duke, 4 hours ago
              Started by 04RoadStar1700, 1 day ago
              Started by Jaybo, 04-04-2021, 09:38 PM
              Started by jimlun, 1 day ago
              Started by Shores, 7 hours ago
              Started by coolalexrex, 10 hours ago
              Started by coolalexrex, 20 hours ago
              Started by Chefturner, 07-01-2018, 11:12 AM
              Started by Sharpman66, 20 hours ago
              Started by LittleMike52, 18 hours ago
              Last Post LittleMike52
              Started by jrbk, 1 day ago
              Started by Papi, 3 days ago
              Started by Jbird, 4 days ago
              Started by Jrose2118, 6 days ago
              Started by goosecustoms, 1 day ago
              Started by LordOfTheBuzzards, 3 days ago
              Started by Sparker, 1 day ago
              Started by gillis.jordan, 2 days ago
              Last Post gillis.jordan
              Started by Dwizzle6123, 1 week ago
