front brake rotor
  • front brake rotor
    ok what rotors will fit on a 03 rs. I know the stock will But is there any upgrades that will wok. thanks
    EBC makes them, but I got some Chinese ones that are quality, identical to OEM and $130 for the pair off eBay.
      I got some SS ones off ebay that seem gread for $65 each
        It's been a while, so this info may be a little fuzzy, but I believe that R1 rotors & calipers will fit the R/S lower legs.
          2002-2003 R1 rotors will fit. EBC or Galfer come to mind.
            If you're talking "upgrade" there's no real benefit to changing your rotors. The only time it's necessary is when they're worn past their minimum thickness. If you want to improve your brakes, before you start throwing any new parts at them, flush the old brake fluid out with a good high temp DOT4 racing fluid, then bleed them *really well*. Brake fluid is the single most neglected maintenance item on a motorcycle. You'd be amazed at how much of a difference it can make. If you're brake lines are old and dry, i.e. show signs of surface cracking or you have visible pieces of black rubber in your old fluid, replace them with a new set of stainless braided brake lines. 9 times out of 10 that's all you need.
              Agreed. Yamaha is already using the basic R1 caliper on them- though I think that might have been an upgrade that came in '04. Stainless lines would be an improvement; or if you're feelin wiley you could put the Galfer petal style rotors on there for a modern cruiser look. Pretty spendy though and unless you're really hot footing it I don't know if you'd see the value.
              Started by Blackbeard, 10 hours ago
              Last Post Blackbeard
              Started by estrom, 4 days ago
              Last Post Baxter85
              Started by JohnnyBGreen, 3 weeks ago
              Started by LUV4RS, 1 day ago
              Started by Blackbeard, 1 day ago
              Started by Cmw2212, 04-26-2018, 07:38 PM
              Started by Sluggerknuckles, 21 hours ago
              Started by Lifeguard, 22 hours ago
              Started by jinxpress, 1 day ago
              250 responses
              86 responses
              Last Post rsokie
              by rsokie
              170 responses
              Last Post StarCruiser06
              Started by gonzarelloz, 4 days ago
              Last Post JimK
              by JimK
              1,009 responses
              Started by mariner3302, 3 days ago
              60 responses
              Last Post Blackcloud12
              Started by Doc_V, 3 days ago
